Super Chips
Old Nov 27, 2007 | 07:13 PM
SUCKMEUP's Avatar
SUCKMEUP
Super Chips
I have one on my truck but when i floor it and go for a good 30 seconds the check engine light comes on, is this natural or could there be something wrong? Also if im in the middle setting and then turn it down to the lower setting that also makes the check engine light come on any help on this or opions would be nice thanks
Old Nov 27, 2007 | 07:31 PM
Benny2002's Avatar
Benny2002
Do you have the micro tuner? If so pull the codes, that would help. I think overboost will cause the check engine light to come on
Old Nov 27, 2007 | 07:47 PM
SUCKMEUP's Avatar
SUCKMEUP
HONESTLY IM NOT SURE WHERE TO DO OR GO TO GET codes pulled this is my 1st diesel truck and sad but true im a newb at this kinda stuff
Old Nov 27, 2007 | 08:15 PM
Benny2002's Avatar
Benny2002
Its cool, does is your superchip, the macro tuner model(programmer), or an actual chip? If its a programmer you can pull the codes yourself You up in Polk county FL
Old Nov 27, 2007 | 09:15 PM
Lovin7.3's Avatar
Lovin7.3
Yeah I have a superchip 1305. Same thing happens...codes will pry tell you that your hpop cant keep up.
Old Nov 27, 2007 | 10:07 PM
Red Monkey's Avatar
Red Monkey
Get a DP Tuner and sell the Superchip, that'll cure your problem. When I used a Superchip programer I also had the SES light pop on when I 'gassed' it in 'tow performance' and 'high performance' mode. After installing my DP Tuner I no longer get the SES light when I'm in the throtle PLUS the truck performs MUCH better...just my .02
Hal
Old Nov 27, 2007 | 11:00 PM
UP_There's Avatar
UP_There
never had any problems with my programmer, I have the micro-max Superchip. Pulling the codes is fairly simple.....just plug it in and follow the prompts on-screen! I am curious about the DP Tuner....but not enough to spend money on another tuner.
Old Nov 28, 2007 | 06:52 AM
HKusp's Avatar
HKusp
Find someone around where you live that has one(DP Tuner), ride in their truck and you will be selling things you might even need to get that DP instead of your Superchip.
Old Nov 28, 2007 | 09:22 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I ran a superchip for 4 years and it was a soooo fast to me. Then I learned about DP-TUNER from here and decided to change. You have no idea the difference between the two. My 80 ecno is twice as fast as the performance on the superchip.
I still use my superchip to read codes and hold down my paperwork in my shop.
Old Nov 28, 2007 | 09:42 AM
99SevenPoint3's Avatar
99SevenPoint3
its probaly one of two things the hpop or overboost ...
Old Nov 28, 2007 | 10:42 AM
03_PSD's Avatar
03_PSD
the check engine light comes on with me too...then goes off, suggesting its the overboost. Does you light go off while your driving after a few minutes, if so then its your overboost. i was about to get the DP then my rear pinion seal decided to go out so i had to replace that, three u-joints and got a new parking brake assembly for 300 and change so the chip is on hold yet again.
Old Nov 28, 2007 | 10:51 AM
nlemerise's Avatar
nlemerise
Originally Posted by miller_feed
... and hold down my paperwork in my shop.
Now that's funny...
Old Nov 28, 2007 | 05:28 PM
Vijay's Avatar
Vijay
SuperChip on mine too, no lights/codes so far...
Old Nov 29, 2007 | 01:39 AM
SUCKMEUP's Avatar
SUCKMEUP
sorry i havnt replied to any of yall been out at work but let me see here yes im up here in polk county (florida) and yea the light shuts off a few minutes after while im driving and about this dp tuner or whatever how is it installed and whats the price on these things ?
Old Nov 29, 2007 | 02:00 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Man, you just don't know. This DP tuner thing is the cat's rear end. Like mentioned, try to find someone close that has one and go for a ride. That is sales. I didn't have that and went through a TS chip which is a good chip in it's own right. I couldn't believe the difference when I went DP. Just do a search, DPTuner. It Googles up just fine.
BTW, that SES error is most likely HPO above/below desired/expected.
