Injector pump Turned down by previous owner?
Also, when crusing along at 60 in high gear, you should hear just a little clatter; if you don't hear anything when under load like this, it's retarded.
Once you advance it and play with the timing until it feels pretty good, by all means, crank up the fuel until you get a little smoke at WOT, then back it off a flat.
Remember that your IP and injectors are probably worn out by now, so it's a matter of either replacing them, or compensating for the wear. Wear tends to manifest in retarded timing, and sometimes less fueling.
Another thing I've run into is fuel starvation caused by a clog somewhere in the lines to the tank or the tank pickup. This manifests with a truck that runs fine at idle and revving it in neutral, but once you get on the highway it feels like it doesn't have much power above 45... and you get /zero/ smoke(because it's not getting enough fuel).
If you think this might be it after doing the other adjustments, one test is simply to grab a can of diesel and strap it to the front bumper.
Run a hose from it down to the mechanical fuel pump on the passenger side of the engine, and drive it around.
Note that you'll want to cut a V shape into the hose end in the can, so it can't get stuck to the side or bottom of the can.
to test for air intrusion, remove the fuel filter after it sits overnight and see if it is full, or part empty. if not full, you have air intrusion.
another trick is to park on a hill with the engine pointing down. if it starts up and stays running every time, it is air intrusion.
parking with engine facing up hill, should make it start/die/not restart.
for the lack of power, try bumping the timing about a dimes width.
Also, if you put new valves in it... you have to have them ground properly. There is a /very critical/ spec on the valve recession, and if you don't have it done right, your valve guides will die quickly as the valve beats a depression into your piston...
If it's still in good shape... don't mess with it. Spend the money on performance parts if you have it; a turbo will really wake up any IDI.
If you are having problems with performance, make sure you are getting enough fuel in the first place. If something's clogged, it just won't have much power.
If it's working right, even NA, it should be able to haul a 250 gallon tote of water(~1 ton) up a decently steep hill at 60 MPH.
Loaded with a 5k+ trailer, yeah, you'll slow down going up a hill(until you put a turbo on it), but unloaded or lightly loaded, it shouldn't do badly.
And really, you are just looking for major differences between them. We've seen new motors up above 500 PSI, and even down to 350 PSI should be fine.
Remember that the hardest thing for a diesel is starting. Once the engine runs, it really needs a /lot/ less compression(and can have /really/ leaky rings and still work fine).
Last engine I had rebuilt, well, half the rings had broken, it had at least .020 of bore taper(with a .010 ridge at the top of the cylinder), and it still ran well enough. Fired right up when cold, with working glow plugs.
I only rebuilt it due to a tick; probably due to a bearing somewhere.
On that engine, yeah, it was slightly sluggish; felt like it had just a little less power than it could have had. Well, until the turbo kicked in at around 1600 RPM, that is. After that, well, the rebuilt engine did /nothing/ different.
There's a reason it's a $500-800 IP instead of a $3-4K IP like a P-pump.
The mechanical pump works quite well for what it is, and is cheap. In good working order, it'll supply far more than your IP needs.
Sure, you might be able to use the turbo itself, but everything else would have to be fabricated - up-pipe, down-pipe and intake hat.
And, if you are going to spend that much time and money fabricating piping, go with a better turbo.
If you are looking for a cheap power boost, the kits from Banks, ATS and Hypermax fit the bill, and can sometimes be found at the junkyard. Ford's own IDI turbo, in some 93-94 trucks is a modified ATS kit, and generally works the same way.
If you want more than the 5-10 PSI of boost and perhaps 220 HP at the wheels you get from one of those, you can find performance turbos and other parts at idiperformance.com. You'll need headstuds if you want to do more than the kits will provide, as well.
once you put a turbo and free flowing exhaust on the engine, it will be like getting out of a volkswagon and getting into a V8 mustang.
