trying to install factory fog lights on my new f-350
the lights are installed but I cant find the correct wiring harness and headlight switch listed for my year ... how far back did Ford use the same stuff ?
Click on the item description, at the bottom, it has a name. (Kevin) and a phone number. I'm willing to bet he can hook you up with the harness and switch. This dealer sells a lot of the oem add on stuff.
The link I provided is for his xlt truck. It will also work with xl trucks that have power windows and locks.
Be aware that the xl kits for manual window and lock trucks, have two different part numbers available, depending on your build date.
