EBPV has me stumped...
Old Dec 16, 2016 | 10:45 AM
thewellman's Avatar
thewellman
Iirc that close / open action you see right post start up is a stock systems function test, regardless of temp. I suppose to show that it is free and actionable, wiring test out, etc. jay
Old Dec 16, 2016 | 11:49 AM
Airstreamer67's Avatar
Airstreamer67
I wired the EBPV with a toggle switch. I use it as an exhaust brake when towing down grades. I also use it as a fast warm-up device like the factory intended. For $20 worth of switch and wiring, it's the best bargain going.
I have an Edge Insight. One of the values I monitor with it is exhaust back pressure, which is reported by the sensor at the top of the exhaust tube coming from the front of the engine's exhaust manifold. It shows how much pressure the EBPV generates, so you can confirm the valve is working as you want it to.
Old Dec 16, 2016 | 12:46 PM
78fordwheelin's Avatar
78fordwheelin
i think that's what I'll end up doing, however I'm gonna keep it hooked to the ECM and just wire a diode into it so I can retain the regular function while driving. It really does make the truck warm up a lot quicker. And the toggle switch will allow me to close it at idle when I first start the truck so it'll actually warm up before I start driving.
Johnmd
28
Jan 16, 2017 12:44 AM
chuck7300
Dec 8, 2008 07:44 PM
03_PSD
Oct 11, 2007 08:38 AM
bad ass diesel
Jan 30, 2007 06:11 PM
georgedavila
1978 - 1996 Big Bronco
Sep 18, 2001 07:54 PM
