5speed swap
Dec 16, 2016 | 08:05 AM
5speed swap
Guy on craigslist is parting out a 97 psd 4x4 5 speed. Claims transmission was rebuilt 10k miles ago. Said he is selling everything you need to do a auto to manual swap got $1500. Transmission, tcase, drive shafts and clutch pedal assembly. What else do I need besides the pcm, and master cylinder? Do u think that's a fair price?
Dec 16, 2016 | 09:00 AM
I think 1500 for everything you listed is fair. Out here the recyclers get that for the tranny and transfer case.
Dec 16, 2016 | 09:27 AM
You need the clutch and flywheel, too.
Dec 16, 2016 | 11:56 AM
Shifter
Floor Pan
Transfer case linkage
Column trim
Gear selector block plate
See how much for the whole parts truck. It's much easier to do the swap when you see where parts are coming from.
Dec 16, 2016 | 01:46 PM
Dec 16, 2016 | 02:18 PM
Yeah I think you're better off reflashing your pcm unless you can get him to give you the one from the truck.
Dec 16, 2016 | 05:05 PM
Need the transmission crossmember and should get the wiring harness also.
Manual steering column and prndl cover for the guage cluster
Dec 17, 2016 | 08:36 AM
^^^^^^ +1 Donor truck, your best bet. If not, for the hydraulics, get a complete pre-built pre-bled kit; waaay easier to install, no bleeding. Column itself is the same, just the cover is different.
Dec 17, 2016 | 08:48 AM
Quote:
Originally Posted by
91 Dually
If you remove the shift handle and change the plastic cover you will have a manual steering column.
Bootlegger's Deluxe
Oct 23, 2016 09:46 PM
DIYMechanic
Ford Truck Parts for Sale
Aug 22, 2012 02:21 PM
Nino Triarsi
Jan 10, 2012 10:08 AM
pkorrupted
Feb 29, 2008 04:09 PM
RTM
Dec 6, 2003 07:37 PM
