High idle won't work
Old Jan 14, 2017 | 05:57 PM
Johnmd's Avatar
Johnmd
I have a 99 f350 and I can't get my truck to kick up the idle when it's cold out. There have been mornings in the negatives and still nothing. I replaced my egr tube and cleaned the exhaust pressure sensor. My exhaust back pressure valve opens and shuts while driving at slow speeds but not while at idle, but I don't know if that's related. I replaced the oil temp sensor with a ford motorcraft one. And I plugged my intake air temperature sensor into a buddy's truck with the same motor and his truck still idled up no problem. I'm stumped now, any ideas what's wrong?
Old Jan 14, 2017 | 07:02 PM
AKHunter93's Avatar
AKHunter93
I don't have the solution to your problem, but I want to follow along because I'm having the same issue. Albeit, mine is a '97 Powerstroke with an auto, but the issue is the same. No high idle regardless of ambient temperature.
Old Jan 14, 2017 | 07:35 PM
Firefighter 1406's Avatar
Firefighter 1406
You said you cleaned the sensor. Are you sure it's not toast? No oil leaks noticed from the valley area? That's were the valve is for the butterfly that closes.
Old Jan 14, 2017 | 07:46 PM
Johnmd's Avatar
Johnmd
Yes I cleaned the exhaust pressure sensor. The exhaust valve is shutting but only after I give it some throttle. I don't know how to tell if it's good or not other than that. I do actually have some oil in my valley but didn't think much of it I thought it could have been left over from when I did my Ipr valve. Does my exhaust valve operation have anything to do with the high idle?
Old Jan 14, 2017 | 08:20 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Because the 95-97 trucks do not have the software capability to "idle up" when cold.
Old Jan 14, 2017 | 08:21 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Manual or automatic transmission?
What is the PCM code? Some do not have the feature built into the calibration.
Old Jan 14, 2017 | 08:30 PM
AKHunter93's Avatar
AKHunter93
I've heard differently, but I'm not educated enough one way or the other to know which is correct.
However, on my dad's '97, he had one of these that was used to control the RPM and set the high idle manually.
Perhaps I need to find one secondhand and install it.
Old Jan 14, 2017 | 08:32 PM
Johnmd's Avatar
Johnmd
I have a 95 that idles up no problem by itself
Old Jan 14, 2017 | 08:33 PM
Johnmd's Avatar
Johnmd
It's an auto, I don't know what the pcm code is right now. But the high idle worked no problem last winter
Old Jan 14, 2017 | 08:41 PM
bigb56's Avatar
bigb56
Does the parking brake have to be engaged (and the dash light on) for the high idle circuit to work on the 7.3?
Old Jan 14, 2017 | 08:43 PM
Johnmd's Avatar
Johnmd
I believe eve only if it's a standard,
Old Jan 14, 2017 | 09:00 PM
timmyboy76's Avatar
timmyboy76
L99 zf6 here, and it's been years since mine would kick in. Not sure if gutting the pedestal, ebpv and bypassing the NSS(nuetral safety switch) if all/any play a role
Old Jan 14, 2017 | 09:49 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Does the light on the dash come on when you engage the parking brake? If not it's most likely that switch.
Old Jan 14, 2017 | 09:53 PM
timmyboy76's Avatar
timmyboy76
Will have to take a gander. Got my daughters' pic in life right corner.
Old Jan 15, 2017 | 12:45 AM
Firefighter 1406
I thought the two worked together along with the pcm to get the truck to idle up when cold. I could be wrong on that, and will be corrected if I am. I am still trying to figure out all the sensors in these trucks myself. I too have one of the AIC (Auxillary Idle Conteol) modules in my trucks. To make it do it's thing you need the parking brake on. But the truck should still idle up on its one when it's cold, mine also woulds like a jet engine. People as me what my truck is doing, I just say it's preparing for takeoff
