Bed choice, and why
Old Dec 17, 2023 | 10:48 PM
  #61
4by4ord's Avatar
4by4ord
I don't mind pulling one of various trailers that i have for the odd times the short bed is too small. Most of the time I find the 6.5 foot bed adequate and the often appreciate the agility of my short bed crew cab. If all they offered was a 8 foot box I'm sure I'd get by with it.
Old Dec 17, 2023 | 10:59 PM
  #62
450>350's Avatar
450>350
They need to reintroduce the Super Camper Special package.
Old Dec 18, 2023 | 05:14 AM
  #63
Joe T's Avatar
Joe T
Originally Posted by Rwhjr
Could a rack solve that problem with either size bed and works much better than leaving the tailgate down? Especially if you have other stuff in the bed.
if you carry it frequently there are plenty of more permanent rack options and if it’s infrequently they sell those ones that pop up/down pretty easily so it doesn’t always have to be there.
I have thought about a headache rack but cement board siding has to lay flat and I am usually picking up more than 1500lbs at a time.
I have my dually for sale and scaling down to one truck, a CCSB. I will just have to grab my trailer when needed.
But I haven’t been hauling material around in the last few years. Not common enough to sweat it.
Old Dec 18, 2023 | 06:41 AM
  #64
RidgwaySD's Avatar
RidgwaySD
Originally Posted by Joe T
siding and minimum framing plate and brace length is 12ft.
I would use the trailer. In fact I usually haul the sleds on a trailer because I have the toolbox, counterweight, and plowing sundries taking up most of the bed.
I think there is less than 16 inches difference between the two SD beds.
Certainly it is up to what people use their trucks for. I want the shortest WB I can get with more interior space than a reg cab but I do not need nor want a crew cab. That and a "short " box fits in my garage, remains maneuverable for plowing driveways in the mountains in the winter, can haul people and gear in the cab and it does the same work as longer trucks. That is just why I made my choice. I have driven and owned enough CCLB trucks to know that isn't what I need or want anymore. I have tried them all, reg cabs, super cabs, quad cabs, crew cabs, mega cabs and short and long beds, srw and drw, you name it. My last three have been SCSB trucks, perfect for my needs and thankful Ford still sells them that way.
Old Dec 18, 2023 | 07:27 AM
  #65
OX2's Avatar
OX2
8 foot. If you put in a 1.5-2 foot wide truck box, you still have 6' to work with.
Also with cap, can fit 10 foot conduits inside with TG closed (low corner in back to high opposite corner in front).
Even with truck box, can fit 4 x 8 sheets inside, under the box (out of the weather with cap).
Also get enough fuel to do 400+ miles towing with no fuel stop.
Old Dec 18, 2023 | 08:13 AM
  #66
dilas's Avatar
dilas
For years I wanted the long bed on the F150 as it’s perfect size for my need and I usually add the shell on it and I occasionally camp in it as it fits my 6’4” size with long bed. Yet it can be painful parking in city streets, and going off road during hunting trips, the shortbed does offer advantages at times. Now that I’m shopping for a Superduty, very glad the shortbed is slightly bigger than the 6’6” as the 8’ would be too long for my need knowing it does offer beneficial at times. It really depends on each’s overall needs. If I own a bigger 5th wheel RV then I probably would go for a LB.
Old Dec 18, 2023 | 11:16 AM
  #67
Desert Don's Avatar
Desert Don
Hell, I liked my 1955 IH R130 with a 9’ box!
Old Dec 18, 2023 | 03:45 PM
  #68
RandyinTN's Avatar
RandyinTN
It is a much easier to load/unload a trailer than to load/unload a truck bed. Especially if the item is heavy and you have a front end loader handy.
Old Dec 18, 2023 | 04:10 PM
  #69
turfengineer's Avatar
turfengineer
I generally like how the 6.75’ bed looks and that’s what I bought. I should have gotten the 8’ bed for the fuel tank size.
Old Dec 18, 2023 | 05:47 PM
  #70
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Not for me. Trailer means I have to bend down and pick it up. Truck bed means I can just slide it out and it's already at belly-carrying height. No lifting.
Old Dec 18, 2023 | 06:28 PM
  #71
Rwhjr's Avatar
Rwhjr
You can get a tank that has a 55 (or is it 60?) gallon capacity for the 6’9” bed if more range than stock is a big priority
Old Dec 18, 2023 | 07:05 PM
  #72
S1njin's Avatar
S1njin
6.75 bed for me. Proportionally I think the truck looks tight with that bed length on a Supercab. Also, I wanted to try to stay somewhat maneuverable as my F150s I had in the past. Use case wise, I'm going to be pulling a travel trailer ~26-28 ft long, so the wheelbase ratio of my truck is perfectly suitable to that length.
Old Dec 18, 2023 | 07:14 PM
  #73
Desert Don's Avatar
Desert Don
For yout listening pleasure
Old Dec 18, 2023 | 09:02 PM
  #74
Dmeyer7681's Avatar
Dmeyer7681
I just took delivery on my 2024 F350 long bed, felt like a bus for a few days after driving my F150 with the 5.5 bed, now that I am used to it cannot wait to fill it camping !
Old Dec 18, 2023 | 10:49 PM
  #75
Edd505's Avatar
Edd505
Originally Posted by oklarado
The 5.5 bed wouldn't be near attractive, from a tax deduction standpoint the bed needs to be over 6' long.
what tax deduction? I have had 8ft beds since 1999 and always will to haul a sheet of drywall, plywood or 2x4's and I don't have an issue with the 5W hitting the cab.
