Sponsored by: Real Truck
Driver side low beam problem
Old Dec 12, 2016 | 04:41 AM
cainster's Avatar
cainster
4wd Low
I have a 99 f250 7.3. My low beam was out on drivers side. The bulb was bad but didn't fix the problem. I have aftermarket lights that I think are sub-par in quality so I suspected the light, however my plow light when plugged in has the same issue. Before I tear into the wiring I wondered if anyone has experienced this same issue. I am guessing the issue is where the plow lights tie in or ahead of that since the same problem is happening with that light also. Thanks for any ideas.
Old Dec 12, 2016 | 07:22 AM
projectSHO89's Avatar
projectSHO89
On the 99 SD, the low beams are individually fused. For the left side, check fuse F9 in the under hood fuse box. F11 is for the right side low beam.
Check for a blown fuse first.
krlotan2731
Nov 23, 2014 05:59 PM
xtal_01
May 10, 2014 11:16 AM
lakewood
Aug 9, 2011 05:55 PM
V-10trk
Mar 14, 2005 06:03 AM
ptd0647
Aug 19, 2004 08:50 AM
