Sponsored by: Real Truck
Transmission problem
Old Dec 11, 2016 | 01:35 PM
Cigarette35's Avatar
Cigarette35
I have a 2006 f250 5.4 4wd with 5r110w trans. Check engine light was blinking and then one day the tranny just stopped working in all gears. Engine code p0751 came up, shift solenoid "A". Changed it, code went away and still no gears. Checked pump pressure, good in all gears, all I can think of now is TCM, any suggestions would help
Old Dec 11, 2016 | 09:04 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's not the TCM. Put it in drive, then park. Do you hear a grinding noise? Will the truck roll more than a foot or two when in park? If the answer to either of these is yes, the problem is in the transfer case, not the transmission.
Old Dec 13, 2016 | 05:16 PM
Cigarette35
Hi Mark, when I switch gears, I hear no grinding, the engine rpm goes down like normal. Truck does not roll in park
Old Dec 13, 2016 | 09:26 PM
Mark Kovalsky
That says that the trans is the problem. I think the trans needs to come out and get torn down to find out what broke.
qman4467
1983 - 2012 Ranger & B-Series
Mar 29, 2010 09:03 PM
Showtime
6.4L Power Stroke Diesel
Nov 3, 2007 12:20 AM
jokerjeff
2004 - 2008 F150
Feb 19, 2007 08:02 PM
sailormon
Nov 10, 2003 11:56 AM
92 Xplorer
Oct 4, 2002 04:29 PM
