General Automotive Discussion
Not turning over
Old Dec 10, 2016 | 04:23 PM
hannibal0268's Avatar
hannibal0268
Not turning over
hey I have a 99 Ford explore I recently discovered that some corrosion and a broken terminal was on my battery and I was wondering what that cause that car excuse me truck not the turnover and what do I need to do to get it operational again
Old Dec 10, 2016 | 11:37 PM
ford2go's Avatar
ford2go
Corrosion is common on battery terminals as they get older.
If you're talking about a broken terminal on the battery cable, then you need a new cable. Available at most auto stores. Probably best to change them both.
- You MIGHT need a new battery as well.
Corrosion would weaken the terminal on the cable.
If it's the actual terminal post on the battery itself, you need a new battery -- wouldn't hurt to get new cables as well.
If the actual battery terminal is broken, it got whacked pretty hard by something.
Truck can't start if the battery isn't well connected.
Good Luck,
hj
brider
May 31, 2012 02:55 AM
BIGRED 7.3L
16
Oct 5, 2011 12:01 PM
WALFORD'S 56
13
Jul 22, 2010 11:20 AM
There Goes The Neighborhood
Electrical Systems/Wiring
Apr 26, 2005 10:38 PM
phyxius
Nov 9, 2004 12:38 AM
