1953 6 volt battery terminal caught fire!!!!
We were coming home from a local car show in the 53 f100,and Terri said...smoke was coming up through the battery box cover, and she was flipping out.
Our German shepherd pup was not happy either, and we pulled over and when I pulled the rubber mat up and the battery lid up......wow the negative battery cable was melted.
It has a brand new 6 volt battery and A brand new rebuilt starter.
I replaced the battery cable and got it home,but why would it get so hot?
thanks ....Bill
thanks ....Bill
Hi Bill,
High resistance is the most probable cause, poor connections..,paint between the ground cable and chassis,"loose" terminals at the cable ends, insufficient grounds from cab to chassis,chassis to engine etc,heavily corroded battery cable etc, etc..give everything a good look-over.Good Luck!
WOW that pic is crazy!! I have always thought the 6 volt cranked too slowly ..so I had starter rebuilt by a guy in Painesville and then when I checked my battery, it was no good.
So I installed new 6 volt battery and cleaned all my wires and connections to solenoid.
I have really thick wires....1gauge....and I now believe the battery terminal and wire end were moving and smoking after cranking the starter.
It melted the crap out of the terminal.
I installed another terminal and got the 53 home.
ALWAYS SOMETHING EXCITING....now the dog won't even jump into the truck...LOL
I think I will replace the voltage regulator next.....Bill
I installed a new cable. The old cable actually melted the lead on the connection. It starts nicer. New starter and cables reallt make a difference!!!
Now if I can get my 71 to start.....UGGGHHH!!!
The 71 f100 has 302 and auto........it has sat for a while, and now no nothing at the key.
The radio works and that is it. SOLENOID? VOLTAGE REGULATOR? FUSIBLE LINK?
ANY IDEAS???
ANY IDEAS???
Bill,
Probably dirty connections on the 71.
How old is the German Shepard pup? I have 2 shepards; one old girl (15 and getting blind and senile) and a pup, well, she's almost 3 so I guess she's not a pup anymore. She's kinda scared of my truck too, its a bit loud for her. She might look big and tough but she's a big sissy....LOL.
They are great dogs!
Bobby
Bobby
I have 3 dogs and they ALL are great in the truck. The pup is o.k.now.....she loves to go in it.....so that being scarred didn't last long....LOL
The 6 volt truck will remain 6 volt. I have way too many trucks and projects to change it to 12 volt. I contemplated it....but have to finish EARL first, and he is coming along fine.
The 71 seems to be totally dead from the battery to the ignition. I don't really need it, so it is on the back-burner....but I like ALL my trucks to run.
I swapped out batteries.....and that wasn't it. ??????
I had a LeSabre Limited that kept killing the battery and turning the starter slow. after taking the starter in and out a few times i got showered with sparks. the cable to the starter had rubbed raw on a frame member just enough to short out. it wasn't visible until it started the light show.
Re 6V battery: Could the new battery be taller than the old one so it shorted on the underside of the cover when the cover had weight on it (passenger, dog)? Is the battery bolted down so it cannot bounce around and short out? If the cover is within 1/4" of the battery top I'd glue a hard rubber pad to the bottom of the cover and check it periodically for wear.
Nate38654
08-21-2016 04:47 PM
F350-6
33
09-04-2010 02:24 PM
