Sponsored by: Real Truck
2016 Trans Temp Range?
Old Feb 5, 2016 | 12:08 AM
Three30Eighr's Avatar
Three30Eighr
Hey guys,
I have a 16 with a 6.2. Truck has less than 1k on it but the tranny seems to run hot. What do these run at?
Old Feb 5, 2016 | 04:48 AM
Just Strokin's Avatar
Just Strokin
What temperature does your transmission show on the readout? What makes you think it is too hot?
Old Feb 5, 2016 | 04:52 AM
redford's Avatar
redford
FTE Leadership Emeritus
There have been a few threads recently which discuss this. Basically, modern transmissions run a little hotter, because this increases the efficiency of the transmission.
Old Feb 5, 2016 | 06:15 AM
rays250's Avatar
rays250
I have a 2016 6.2 2500 miles so far notice temp running around 200 to 208. Haven't towed yet but im sure it will go up. My 2012 F150 would run 190 and towing about 198 to 202. Im not sure what normal range is for these temps but the gauge on the dash doesn't seem to be affected at all. So must be normal.
Old Feb 5, 2016 | 06:33 AM
Dom165's Avatar
Dom165
My 2016 has less than 500 miles so far. Mine seems run at 196 when I check the information center. At that temp it is still well within the normal range on the gauge. I have not towed anything yet either.
Old Feb 5, 2016 | 07:39 AM
The Bone's Avatar
The Bone
I have a diesel so may not be a direct comparison but miner is within 2 or 3 degrees of engine temp.
Old Feb 5, 2016 | 08:53 AM
Tom's Avatar
Tom
Around 190-200 is pretty normal for these transmissions. They use a thermostat to control temperature, so you're going to see temperatures like that year-round.
Old Feb 5, 2016 | 12:06 PM
2016F350in NSB's Avatar
2016F350in NSB
Is this in the info center of an XL?
Old Feb 5, 2016 | 03:38 PM
Tom's Avatar
Tom
Not to my knowledge, I believe it only is shown on models with the 4.2" LCD screen.
Old Feb 5, 2016 | 08:07 PM
Three30Eighr
XLT mine runs up to 209...cold weather no towing etc.
Old Feb 5, 2016 | 08:33 PM
Tom's Avatar
Tom
Sounds on the high side of normal to me. Stop-and-go traffic can make transmission temperatures rise, but I'd be really surprised if it got much over that. As it climbs the thermostat opens and the cooling system starts working. You have a LARGE transmission cooler, I've never heard of someone overheating one of them.
kx125str99
19
Dec 20, 2016 07:51 PM
mark224
Dec 9, 2016 09:29 PM
mustang9701
Jan 2, 2013 04:53 PM
hedhntr
50
Jun 21, 2006 10:25 AM
schrubmeister
1997 - 2003 F150
13
Dec 1, 2004 09:11 PM
