Normal trans temp?
Old Apr 8, 2014 | 03:14 PM
jyarosz's Avatar
jyarosz
Normal trans temp?
I recently bought a 2013 F150 XLT 5.0 4x4.When I switch to the gauge readout the trans temp is about 195 degrees at highway speeds warmed up.I am going to tow a 6k lb trailer tommorow about 400 mile.The air temp should be about 60 degrees.What is the highest trans temp I should see?Is there a warning if the temp gets too high?
Old Apr 8, 2014 | 03:31 PM
RigTrash601's Avatar
RigTrash601
My transmission normally runs in the 195 range, I recently towed a 16' Box trailer (trailer and cargo about 6,000#) The most I saw was 197. Which it will get that hot in stop and go traffic. I asked the same thing when I got on FTE, but others have also indicated theirs run in the 190's. You shouldn't have any issues.
Old Apr 8, 2014 | 06:48 PM
MCDavis's Avatar
MCDavis
196* is the norm for the most part.
IIRC Tom hit the low 210*s when he was pulling the hill at the Ohio meet last summer. Albeit they were pulling about 15klbs in that test though.
Old Apr 8, 2014 | 08:15 PM
Tom's Avatar
Tom
Actually I think I was around 223°, but I'm too lazy to look it up. Warmer than 210° though, but not by a whole lot.
These transmissions use a thermostat to regulate temperature, so it's normal to see 195° unloaded. I've never seen it get much above 205° when towing heavy under normal conditions.
6.2L V8
13
Jun 6, 2017 08:59 PM
mark224
Dec 9, 2016 09:29 PM
st.rodder2
Sep 1, 2016 09:25 AM
tuf4x4
Jul 23, 2011 05:32 PM
dinty01
Jan 26, 2005 11:37 PM
