rear hatch key
Old Dec 8, 2016 | 10:38 PM
mastiff23's Avatar
mastiff23
rear hatch key
Just going thru the tech folder for fixing a non locking rear hatch but just a quick question is the rear the same key as my ignition key or is there a separate key for the rear.i ask because my 95 bronco has 2 separate keys.thanks!
Old Dec 8, 2016 | 10:45 PM
ScottieGT500's Avatar
ScottieGT500
It should be the same as your ignition key. Mine just stopped working as well. I can hear it doing something in there when I open the glass hatch but it will not lock/unlock with door lock switch or key fob
Old Dec 8, 2016 | 10:50 PM
mastiff23's Avatar
mastiff23
OK Thanks!
Old Dec 9, 2016 | 02:21 PM
wpnaes's Avatar
wpnaes
Open it up from the inside and see what's bent or needs some lube. They're pretty easy to fix if you can remove some screws and panels.
Old Dec 10, 2016 | 01:22 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by mastiff23
...is the rear the same key as my ignition key
Yep.
Check out the tech folder sticky thread for options and ideas.
Like Sean stated above, check out the tech folder sticky thread and you'll find help there for what Sean is advising.
Stewart
Old Dec 10, 2016 | 01:45 PM
Apocalypse's Avatar
Apocalypse
Mine's been broken since I bought it. I really need to fix it
Old Dec 10, 2016 | 01:47 PM
Apocalypse's Avatar
Apocalypse
Old Dec 10, 2016 | 01:58 PM
Stewart_H's Avatar
Stewart_H
Instead of posting direct links Apoc, please direct them to look in the tech folder.
Posting direct links in a way defeats the purpose of having the folder, which is a resource that should be used first.
Stewart
Old Dec 10, 2016 | 02:59 PM
Apocalypse's Avatar
Apocalypse
Stewart
........Fixed
Old Dec 10, 2016 | 05:51 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by Apocalypse
........Fixed
Thanks!
I've only asked this of the regulars and veterans of the site.
It's kinda like the adage, if you give a man a fish, you feed him for a day. But if you teach a man how to fish, he'll refer to the tech folder as his first option, and pass the word.
Stewart
munireusa
Apr 27, 2017 08:26 AM
Skip1970
Mar 16, 2010 02:04 PM
1986fordrangerman
1997 - 2003 F150
Dec 10, 2008 05:22 PM
K2JJB
Jun 4, 2004 09:22 PM
timmyjoe
Mar 2, 2004 08:19 AM
