confused
Old Dec 8, 2016 | 06:33 PM
firstfordrestore's Avatar
firstfordrestore
confused
HELLO EVERYONE, MY SON AND I ARE RESTORING A 66 F100 SWB 4WD ,THIS IS MY FIRST FORD REBUILD AND EXCUSE ME FOR BEING REALLY LOST, AND I MEAN LOST LOL.MY QUESTION IS WHAT IS THE DIFFERENCE IN THE 2WD AND 4WD FRONT CAB SUPPORTS, ONE PLACE TELLS ME NO DIFFERENT AND 5 OTHERS SAY THAT THEY ONLY HAVE 2WD. Any help would be greatly appreciated and if anyone knows where I could find the 4wd 2 piece cab supports. Thanks for your help
Old Dec 8, 2016 | 11:04 PM
James_Western_Canada's Avatar
firstfordrestore: Welcome! (and BTW: On the computer, using caps is considered shouting)
this might clear things up a bit?
Slick 60's ? View topic - cabs. will it fit ?
James
Old Dec 9, 2016 | 03:12 AM
firstfordrestore
Sorry about the caps couldn't get them to turn off and I wasn't meaning to yell. It does shine some light on this and does anyone know where I could find a set of the mounts at
Old Dec 9, 2016 | 09:13 AM
firstfordrestore: There are only two different types of front cab mounts, and they are easy to tell apart.
The early cabs (61-64), and the 65-66 heavy trucks (F350 & larger) with the stepwells use these
*also '65 4x4 cabs, and '66 F250 4x4 (and if I has mispoken, Number Dummy will be along to show me the error of my ways
The 65-66 twin I beam cabs, and the 66 F100 4x4 use these mounts
Tom @ Flashback F100's has both
Flashback F100's - USA Made Steel Made Repair Panels On This page will be only USA Made Repair Panels,, not like others that carry those Black Tawain cheap repair panels, Here is how I feel on ste
HTH
James
Old Dec 9, 2016 | 02:54 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I'd like to see pictures of your truck. One of the warranty plate on the drivers door would be welcome, too.
Thanks
Chad
Old Dec 9, 2016 | 05:25 PM
firstfordrestore
This is the frame work that has been finished
Old Dec 9, 2016 | 06:00 PM
firstfordrestore
This is the truck before we started the off frame
Old Dec 9, 2016 | 06:15 PM
So, there's your answer, you need this style of cab mount!
James
Old Dec 9, 2016 | 06:20 PM
firstfordrestore
Thanks James, I hope you don't mind if I pick yalls brains for info in the future. I have added some pics Chad I'll take some more of the cab when I get some more time on it
Old Dec 9, 2016 | 06:24 PM
firstfordrestore
Old Dec 9, 2016 | 07:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F11 = F100 4WD
Y = 352 2V
R = San Jose CA Assembly Plant.
848631 = 1966, assembled April 1966.
115" Wheelbase.
FM: F = Light Blue / M = Wimbledon White.
F110 = F100 4WD .. 5,600 lbs. GVWR
B81: B = Medium Blue Crush Vinyl & Medium Blue Cody Pattern Woven Plastic / 81 = 81B Custom Cab.
A = New Process 435 4 Speed Manual Transmission.
A9 = Spicer/Dana 60.3 Rear Axle / 3.54-1 / Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,600 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
738986:
73 = Salt Lake City UT Ford District Sales Office, where the original selling dealer ordered the truck from.
8986 = Domestic Special Order number, truck special ordered by the original purchaser, not "bought off the lot."
Old Dec 9, 2016 | 08:21 PM
firstfordrestore
Thanks numberdummy that good information, I have read some options on the HD truck do you know of any or is this just a plain Ole special order
Pooter91
Feb 19, 2018 09:57 AM
hoss73ford
May 16, 2016 10:13 AM
Marky48170
19
Mar 9, 2016 09:19 AM
FordF100man
Sep 22, 2014 12:46 AM
AlaskanEx
Aug 1, 2010 10:31 PM
