Oil leak
Old Dec 8, 2016 | 01:56 PM
MTP55's Avatar
MTP55
Oil leak
I am bidding on a 97 f250 that has a rough body and an oil leak on drivers side midway up the engine maybe. Anyone know what that is and cost to repair? Help is appreciated.
Old Dec 8, 2016 | 02:09 PM
knottyrope's Avatar
knottyrope
oil cooler maybe
Old Dec 8, 2016 | 02:28 PM
lee00's Avatar
lee00
valve cover gasket...or fuel lines maybe
Old Dec 8, 2016 | 02:30 PM
MTP55's Avatar
MTP55
What is the cost to fix?
Old Dec 8, 2016 | 02:36 PM
lee00's Avatar
lee00
Depends on what the issues is...most of us here would buy the parts to fix any of the above issues and do it our selves.
Old Dec 8, 2016 | 02:42 PM
MTP55's Avatar
MTP55
I would fix it myself.
Old Dec 9, 2016 | 07:42 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Possibly (worst case) oil pan seal?
Old Dec 9, 2016 | 09:21 AM
aaron8669's Avatar
aaron8669
When you say "midway up the engine", are you taking about back to front or top to bottom? You might check on top of the motor. These engines have some common oil leak that actually start at the top (hpop or oil lines) and appear to be rear main seals and other things. Good way to tell is trying to look at the intake valley and make sure it's dry. If it's dry and where your oil lines attach to the heads are dry then you most likely have some sort of gasket leak. As in cost to fix, I agree with the above statements. Most of us buy the parts and fix ourselves so it's hard to say outside of potential parts cost. Maybe submit some pics of the leak to take the guess work out of it.
Bearhugger1933
Dec 2, 2016 06:03 AM
dmanshane
Dec 1, 2013 07:30 PM
baker1983
Jan 5, 2013 09:40 PM
rich gill
Nov 19, 2008 08:08 PM
2 stroke man
Aug 24, 2007 09:21 AM
