I have a pretty good oil leak up front,replaced orings in oil cooler a while back,a while back some one had a picture of the motor and places where the leak could be coming from,but I didn't save it. Thanks
Jim
It,s not coming from the valley,looks like it is mostly coming from up high,more to the driver side there are three small lines that are tied together wonder if there is a oring there,don't know what all of these places are called..thanks
Might be a fuel leak, clean you engine the best you can and try to pin point exactly where its coming from. Also look at the oil gallery plugs they tend to leak there's two on each head, check the one behind the ac compressor ( they have a 1/2" drive)
Have you checked the o-ring on the cam position sensor? It can leak on the damper and spray oil everywhere. Just a thought. Stranger things have happened.
Check your HPOP near the front of the engine. I have noticed a small oil leak coming from my HPOP reservoir or HPOP sealing gasket up front. Its a very slow leak but it drips down the front of the case and onto the fuel supply/return lines and then onto the chassis. Oil is very deceptive when trying to find the source of the leak!
