89 Problems - HELP!
Old Dec 8, 2016 | 02:06 PM
FordMac1's Avatar
FordMac1
The 14GA Fuselink wire that’s stripped (circled in red up above), looks like it runs into the alternator from what I can tell.
Old Dec 8, 2016 | 02:18 PM
FordMac1's Avatar
FordMac1
When I plugged in my digital code reader while KOEO, I received the following...
21 O – Cooling temperature sensor out of specified range or ECT out of range.
22 O – Manifold Absolute Pressure (MAP) or BARO sensor out of range.
24 O – Intake Air Charge Temperature (ACT, IAT) sensor or Vane Air Temperature (VAT) sensor out of range.
67 O – A/C input high
10 – Clear/Reset
11 C – System OK
Old Dec 8, 2016 | 02:22 PM
joey2fords's Avatar
joey2fords
then, if your "chugchugchug" is at a normal speed, the problem is not in your starting system and you need to start looking at fuel and spark. considering that you have been able to start it on occasion, i would (for the moment) rule out a spark issue and would start looking at fuel. you are going to need to buy, rent, or borrow a fuel pressure gauge and test fuel pressure. fortunately, ford made this easy by putting a schraeder valve on the fuel rail.
also, when you turn the key to the "run" position, you should hear your fuel pump run for a second then stop.
Old Dec 8, 2016 | 02:42 PM
FordMac1's Avatar
FordMac1
The fuel pump and/or pressure was my next thought, thank you for confirming this step for me!
war1ock
13
Sep 10, 2012 07:37 PM
xirxious
29
Feb 26, 2010 03:23 PM
ranger1999 Bob
Feb 7, 2008 07:43 AM
stevetopps
Nov 11, 2007 03:10 PM
ford racer 02
Jan 15, 2006 07:09 PM
