Plow seasons here
Old Dec 6, 2016 | 06:16 AM
Sledhead3's Avatar
Sledhead3
Plow seasons here
Well it's started,snow..my 97 powerstroke e fuel conversion worked.however excessive pressure 90psi is causing a problem . can I install a facet electric lift pump in place of the stock "pusher" e pump? I'm trying to drop pressure to stock fuel bowl assembly . without a regulator . seems to me it should work . see it used on idi,
why not a powerstroke ?
Old Dec 6, 2016 | 09:05 PM
Jarrett Campbell's Avatar
Jarrett Campbell
Wait... So you installed an eclectic pump and still have the bowl... You still have the stock mechanical pump too?
Old Dec 8, 2016 | 06:23 AM
Sledhead3's Avatar
Sledhead3
No I have eliminated the mechanical fuel pump completely out of the Valley of Death and installed a stock 2002 electric fuel pump on the cab. It's rated for 56 PSI the pump however my pressure gauges indicate that by the time it gets to the fuel bowl it's making 90 PSI. I believe the restrictions in the line created by the tank selector valve on the frame is upping the pressure. I want to lessen the pressure to the stock fuel bowl by putting in a dura lift (faccet) electric pump. Outside of excessive fuel consumption and it now takes 4 seconds to start the truck rather than two it works very well . I've seen it in an IDI ,just seeing if anyone has ever used it in a powerstroke .
Old Dec 8, 2016 | 11:28 AM
knottyrope's Avatar
knottyrope
tank valve should not be making much of a restriction
maybe your valve is failing
Old Dec 8, 2016 | 01:03 PM
cowmilker08's Avatar
cowmilker08
Are you still using the stock fuel bowl or a SD fuel bowl?
NBC-Steve
15
Feb 16, 2014 10:51 AM
fixnair
May 10, 2013 09:42 AM
TNT in Round Rock
Aug 9, 2007 05:04 AM
jcruth
Mar 6, 2007 12:42 AM
meck1
Jan 26, 2006 06:32 AM
