gpm of fuel pump??
The standard manual lift pump........
Carter pump #M60278
Pressure Rating: 4 lb - 6 lb
Gallons Per Hour: 23
The IP really only needs 2 psi.
The Holley red is:
Free Flow Rate: 97 gph
Maximum Pressure (psi): 7 psi
Why would anyone want to circulate 3 times the fuel required for no reason.
Carter pump #M60278
The Holley red is:
roadrash63
08-11-2010 02:28 PM
saltydogs
06-21-2003 10:11 PM
