351m to 460
Old Dec 4, 2016 | 03:00 PM
7379ford's Avatar
7379ford
351m to 460
I got a 78 ranger 4x4, it has a locked up 351m I have a chance to get my hands on a 87 460, came out of an f350. Any problems I should be aware of and would a stock y pipe with the 80s manifolds fit in this truck? Thanks in advance
Old Dec 6, 2016 | 04:16 PM
Pkupman82's Avatar
Pkupman82
I don't believe the 80s manifolds will clear the frame rail. More specifically the passenger side. A buddy of mine did a 460 swap in place of the original 400 in a 78 Bronco. I seem to recall him having fitment issues, the 460 he bought came out of an 80s-90s era truck. I ended up giving him the manifolds off my 460 after switching to headers. Do yourself a favor and buy the 460 conversion mounts, it will fall right into place without a hitch. You can buy the L&L mounts or Bronco Graveyard has their extreme duty 460 swap mounts. I went with the ones from JBG, fit perfectly and are holding up well.
Old Dec 6, 2016 | 04:20 PM
7379ford's Avatar
7379ford
i was doing even deeper search there was a form that said it's better to use the 460 out of a truck or van from 70s or 80s
Old Dec 6, 2016 | 04:24 PM
Pkupman82's Avatar
Pkupman82
More than likely because the later model truck 460s went to a rear sump oil pan. The front sump pans had clearance issues with the front axle on 4x4 trucks.
Old Dec 8, 2016 | 12:36 PM
redmt79's Avatar
redmt79
What transmission do you have in your '78?
Old Dec 8, 2016 | 01:02 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
E5HZ-9430-D (replaced D5TZ-9430-C) Right & E5HZ-9431-C (replaced D5TZ-9431-A) .. 460 Exhaust Manifolds / Obsolete
1975 E250/350 & F100/350 from serial number W00,001 / 1975/79 F150/350 / 1976/88 E250/350 / 1983/88 F250/350.
Old Dec 8, 2016 | 04:58 PM
7379ford's Avatar
7379ford
c6 auto with np203
Old Dec 8, 2016 | 05:01 PM
7379ford's Avatar
7379ford
so f150/350 from 76-88 share same exhaust manifold?
Old Dec 8, 2016 | 05:09 PM
NumberDummy
F150/350 & E250/350: 1975 from serial number W00,001, 1976-88 share same exhaust manifolds.
Old Dec 9, 2016 | 11:14 AM
redmt79's Avatar
redmt79
c6 auto with np203
Good, the C6 will make the swap easier. The '87 should be a good candidate for you then, especially since you will get the correct pan and manifolds. Are you getting all the front accessories with it as well?
As mentioned, you can use a set of conversion motor mounts. You may also need an aftermarket power steering bracket (such as from L&L) to remedy clearance issues with the steering box. Or you can modify your own if your handy. They also make a high-mount alternator bracket that works slick if you run into clearance issues with the front cross-member.
Old Dec 9, 2016 | 01:24 PM
7379ford's Avatar
7379ford
yes it's complete from carb to oil pan, also I planned on l n l brackets as well thank you for the help!
79FordBlake
1978 - 1996 Big Bronco
17
Jul 15, 2014 04:51 PM
79F250RepoTruck
Mar 26, 2012 08:03 AM
mean87stang
May 9, 2006 08:01 PM
fordlowboy
Feb 25, 2002 08:55 AM
ohio bob
Feb 19, 2001 09:34 AM
