Change
Old Dec 4, 2016 | 02:55 AM
cosmo10's Avatar
cosmo10
Change
is there any way to convert a 1987 to just a 1987 ford pick up without all the smog stuff
with out the little computer box just a plane raw engin like a normal V8 without all the extra stuff
thanks guys and gals
Old Dec 4, 2016 | 04:28 AM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
You will need a Delorean with the flux capacitor option. Set the date anytime before 1985 and bring the speed up to precisely 87 mph. Better make that before 1983 so you can avoid those pesky electronic controlled carburetors.
Old Dec 4, 2016 | 10:43 AM
rla2005's Avatar
rla2005
A carb and a Duraspark II could be easily done if the current truck has a manual or C6/AOD transmission. If it has an E4OD then it becomes a much bigger swap because the same engine computer also controls the transmission.
If the current vehicle is running well then why go through this exercise to downgrade?
Old Dec 4, 2016 | 02:35 PM
Lead Head's Avatar
Lead Head
What engine do you have?
IDIDieselJohn
Mar 9, 2011 04:49 PM
caveman524
Nov 17, 2008 07:47 AM
73f-1
Oct 3, 2008 08:08 PM
AZAV8
Engine Swaps
May 13, 2007 04:25 AM
rig2
Apr 20, 2005 08:25 AM
