How do I remove these fuel lines?
Old Dec 3, 2016 | 11:27 PM
1972fordhighboy2's Avatar
1972fordhighboy2
Hey there guys I own a 1989 f350 with a 460 fuel injection. I am currently taking the top end apart because of blown head gasket. I am trying to remove these fuel lines so I can remove the intake manifold. Any suggestions or tips , thanks. Trying to disconect These 2 chromed looking things so i could pull this whole intake.
Old Dec 4, 2016 | 12:31 AM
mrollings53's Avatar
mrollings53
It would probably be easier to remove them from the injectors first. Those chrome bits may not even come apart, but you know they have to come off the injectors.
Old Dec 4, 2016 | 03:25 AM
RadioControlGuy85's Avatar
RadioControlGuy85
you need a special fuel line removel tool you cant get them at autozone for like 10 bucks or so
Old Dec 4, 2016 | 06:57 AM
subford's Avatar
subford
The tool set below will work.
a. Fit tool to coupling so tool can enter cage to release garter spring.
b. Push the tool into the cage opening to release female fitting from garter spring.
c. Pull the coupling male and female fittings apart.
d. Remove the tool from the disconnected coupling.
Old Dec 4, 2016 | 10:12 AM
timbersteel's Avatar
timbersteel
It will help to spray some penetrating fluid inside the ends to help loosen the crud up and slip apart.
Use the tool Subford mentioned and they will slid apart..after some gentle pushing and pulling.
Old Dec 4, 2016 | 02:40 PM
Lead Head's Avatar
Lead Head
Yup, just go to AutoZone and ask for a Ford fuel line tool. They'll know what you're talking about.
bulletsneverlie
Oct 6, 2009 09:13 PM
straightsixer
Nov 28, 2008 03:35 PM
grizz3000
Jul 30, 2007 11:21 PM
JasonSmith
Modular V10 (6.8l)
Nov 2, 2005 10:37 AM
MustangGT221
Sep 26, 2004 07:19 AM
