2001 7.3 puzzled, need help.
Old Dec 3, 2016 | 11:40 AM
gordons's Avatar
gordons
Truck started losing power then service engine light came on, drove about another mile then it just stalled ( almost home lees than a 1/4 mile). Got out open hood oil everywhere on top of motor. Looked under truck and oil all over the road. Looked back where I was driving a line of oil as far an I could see. Checked oil barely any on stick. Where should I start hpop or plug?
Old Dec 3, 2016 | 11:47 AM
coax9952's Avatar
coax9952
Only thing I know of that will drain you out that quick is one of your HPOP oil lines, have they ever been replaced?
and when did you check your oil last?
Old Dec 3, 2016 | 11:50 AM
coax9952's Avatar
coax9952
your motor shut itself off to protect itself, Either get it towed, or fill up your crankcase and scoot for home trailing oil........
Old Dec 3, 2016 | 11:52 AM
gordons's Avatar
gordons
Check oil it was good about a week ago. I have had truck for a little over a year don't know if lines have been replaced. It has 190,000 mile.
Old Dec 3, 2016 | 12:00 PM
gordons's Avatar
gordons
I knew the motor shut off for that reason after I seen all the oil. Will have to look at the hpop lines again.
Old Dec 3, 2016 | 12:04 PM
coax9952's Avatar
coax9952
well, your in the zone, be careful looking around under there with it running, That's very high pressure oil in there. It will bite you if you are not........ Everything else is pretty much O rings on the topside, they won't bleed out as fast.
Old Dec 3, 2016 | 12:08 PM
coax9952's Avatar
coax9952
Not to mention, if it's pretty soaked up there, you've got some Fire danger goin' on too...Caution.....
Old Dec 3, 2016 | 12:16 PM
Bonanza35's Avatar
Bonanza35
I'd tow it home, wash the motor down really good, replace both HPO lines and fill with oil. Then see how she runs. You will have some air in there but it should clear out. After you wash it down also check your HPOP really close to make sure it is intact.
brokedown48
Feb 3, 2014 12:39 PM
davbeisner
Jul 28, 2012 07:28 AM
TC-PStroke
28
Mar 20, 2012 10:47 PM
Rob.D
Oct 31, 2008 08:14 AM
dlc
Jan 14, 2007 07:22 AM
