Sponsored by: Real Truck
oil overfull ?
Old Feb 3, 2014 | 11:57 AM
brokedown48's Avatar
brokedown48
Exclamation oil overfull ?
I have a problem that I don't understand. I have an '02 7.3 with 250,000 miles on it, the last 2 times I have done an oil change, after I run the truck a little bit , it shows WAY overfull ( 3# coffee can overfull) I drained it out last time, then after a bit, it showed low, so I put oil back in, this was about a week of driving. this last time I changed oil, left house, everything fine, had to hit passing gear, then yellow check engine lite came on, checked oil, way overfull. This is my second 7.3 and I have never had this problem, its almost like it needs to burp. ANY IDEAS thanks
Old Feb 3, 2014 | 11:58 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Pull and sample and send it in to check for fuel dilution?
Kdr358's Avatar
Kdr358
Could be a number of things but the oil cooler O rings are a suspect as well as injector cups. Is the oil discolored or have a strange smell to it?
Old Feb 3, 2014 | 12:23 PM
brokedown48
oil does not seem to be diluted down, or have off smell. I drained it down last time to the "full mark" then after awhile the oil level was low, so I added the oil back that I had drained out, and that was the right amount to put it back on "full mark ". I forgot to mention that when check engine light came on, when I stopped , light went off and has not come on again. thanks
droldsmorland's Avatar
droldsmorland
X3 on fuel dilution. Your "making oil". On a diesel thats a tell-tail sign of fuel leaking into the crankcase from something, likely injector cups. If it runs fine that can rule out dribbling injectors. If its not running fine start there. Get to it quick as your washing down your rings and bearings.
Old Feb 3, 2014 | 12:39 PM
brokedown48
Thanks for the info, not really what I wanted to hear, but that's my luck.
Truck runs good, so I guess I can omit injectors. Is there anyway I can check things , to rule stuff out. Thanks for the info & quick reply
SJMaye
2015 - 2020 F150
Oct 2, 2018 09:31 PM
EcoboostKev
17
Nov 26, 2014 07:52 PM
Jerry Chaney
21
Dec 23, 2013 08:06 PM
davbeisner
Jul 28, 2012 07:28 AM
Itsmejoe231
1997 - 2003 F150
Aug 31, 2005 04:11 PM
