'79 Bronco harness replacement
What would you do about this A/C deicing connector? I'm a bit leery of opening up that giant box from the inside of the cab and not entirely sure what I'd be able to do anyhow. The wires appear to have melted on both sides of the connector and A/C is not something the American Autowire harness provides new wire for.
Ford Wiring Harness
Ford - Complete Wiring Kit, 1973-1979 F100-F350 & 1978-1979 Bronco - Macs Auto Parts
Painless Performance Products 50002: 21-Circuit Pro Street Wiring Harness For Street-Legal Race Cars | JEGS
Can you figure out WHY that wire got so hot? I would do that 1st and then repair accordingly.
I have 2 79 parts Bronco's and I have removed the big box out of one. And disassembled it to part it out. The overall harness has given up parts and pieces over time. But if you need a certain part that is a/c related wiring wise just PM me.
I have a couple of real informative a/c links (with tons of info and pics) saved on my home computer.
Here you go.
http://www.rowand.net/Shop/Cars/1979FordF100/AC.htm
http://www.ncspecialties.com/shop/heater/index.htm
Here you go.
1979 F100 Air Conditioning
NORTH COUNTRY SPECIALTIES ®
My exterior lighting run to the rear, including the fuel gauge reading, appears to be connectorized using an 8-position rectangular green connector. All the wiring leading to the rear of the truck is in great shape, so I'm not planning to replace it with the AAW run. Despite looking closely at schematics, I'm not sure what each of the pins in the connector go to - I want to adapt the AAW harness to this connector, so need to know the pin out.
Any help is appreciated!
