I have noticed that my mileage has dropped over the last year. I use to get 17-19 real easily. now i'm getting 13-15 doesn't matter if its country roads, highway, or interstate. I have sct with matts tunes I have tried all 3 of the tunes with the same results 8k tow has been the one that usually gets a little better mileage. I put about 8k miles on it a year change fuel filters every fall, oil change 5-6k miles, air filter every other year. wondering if there is anything that I should check as to why mileage went down so much.
You live west of me up here in the frost belt you are getting "winter fuel" Different seasonal blends usually less BTU's = lower efficiency so yes you will see a drop in mileage this time of year. Can't explain why the drop in the summer months.....
And too add along with that is the longer idle times letting it warm up will burn more fuel with no miles to show for it. If used for short local drives it will be more drastic.
