Bad FICM?
Old Dec 6, 2016 | 10:49 AM
Meltz's Avatar
Meltz
Bad FICM?
I took my truck into a shop because of rough cold starts, I was thinking I may need an injector or 2. They call me today and tell me I need a new FICM, they say they are getting 32v.
I own a cts2 and I watch the voltage through the entire time I am running the truck and have seen it as low as 46 while driving but almost every time I start it, it stays at 47-48.
My question, how are they getting 32?? They said they did not take the ficm out of the truck to test it.
Anyway do need a ficm? If so, Any recommendations? I know ficmrepair.com, what service level from there would you guys recommend from them? Also bulletproofdiesel is selling theirs for $495. Which one to go with? The shop quoted me $840 installed for a bullet proof diesel one, sounds like a rip off to me seeing other options available.
Old Dec 6, 2016 | 11:15 AM
Copper.Farm's Avatar
Copper.Farm
If you go to a Ford Dealer, Ford Mechanic - they are bound by Ford rules for diagnostics, repair, parts and replacements. This usually results in a recommendation to Replace the FICM as they are not allowed to repair the internals.
If you do the research you'll eventually find that the FICM diagnostics that show FICM output voltage less than 48v is caused by the FICM Power Supply board failing - if you have the desire you can repair the FICM yourself:
If motor is >= 2004 then you probably have a four pin FICM
1 - watch a youtube video on FICM Power Supply
2 - order a replacement FICM Power Supply from one of multiple sources, I recommend Made In USA
3 - remove the FICM, be gentle with the connections
4 - Separate the FICM case and swap out the power supply board
5 - re-install the FICM
* No soldering required.
OR
Ed at ficmrepair.com can help you out.
To diagnose: Connect a voltage meter to the FICM Power Output, at immediate key on you will see the voltage, if less than 46v ~ 48v then the FICM Power Supply board is on its way out. It is possible to diagnose without removing the FICM, just have to find the right wire to test.
Good luck.
Old Dec 6, 2016 | 03:34 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
His page says he has a 07.
Cruiseomatic
Oct 22, 2018 02:53 PM
quietman
Jan 25, 2017 08:59 PM
BCphil
Jan 19, 2016 04:48 PM
jay28660
Nov 18, 2011 03:48 AM
robtinalimon
Ohio Chapter
Dec 29, 2004 09:58 PM
