IHOP NON-SERVICE PLUG
Old Nov 30, 2016 | 06:16 PM
GEugeneS's Avatar
GEugeneS
So I have had to put off fixing the oil leak because of some medical issues, but got back on it today. Took out the IPR, then the non-serviceable plug with the plug facing upward so I wouldn't lose the little ball in there. Plug was loose so I assume that was at least part of the leak issue.
However, carefully taping the pump inside an oil pan, out came the edge filter but no ball. Tapped some more - nothing. Tapped harder - still no ball. tapped hard to no avail. Put a little HP air in there, not too much - NOTHING. Squirted a little brake cleaner in there - still nothing. More air - nothing. Where's the ball??? and what do I do now?
Old Nov 30, 2016 | 06:38 PM
pirschwagon's Avatar
pirschwagon
Did you remove the Pump? Post is a little ambiguous to me. But, I'm not that smart anyway. Just to make sure we're not mixing apples and oranges..... her is a Picture for Reference.
Old Nov 30, 2016 | 06:44 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
I agree. I am a little confused by the OP's post.
Thanks for posting a picture for reference. That should help the OP out and ensure he is using correct terminology.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old Nov 30, 2016 | 07:03 PM
GEugeneS's Avatar
GEugeneS
Pump is out. I was afraid of losing the ball if i left it in.
Old Nov 30, 2016 | 07:59 PM
Rikster-7700's Avatar
Rikster-7700
Where are the pancakes?? I was hoping for pancakes........
Old Nov 30, 2016 | 08:37 PM
bigb56's Avatar
bigb56
Why would there be pancakes?? He specifically said this was a plug for NON SERVICE at ihop. If he went to ihop and didn't get any service how would he have any pancakes???
Old Nov 30, 2016 | 09:55 PM
GEugeneS's Avatar
GEugeneS
Sorry, Freudian slip. guess I was hungry. Still can't find the ball under the plug though. What do I do now?
Old Nov 30, 2016 | 10:29 PM
pirschwagon
Can you see the round raised hemispherical end at the bottom of the hole with the edge filter removed? Sometimes they get stuck. If you do see it, be very careful removing it. Otherwise, just leave it alone. But don't mar it. If it's not there, you'll need to find it. If you were having issues before this could be the problem. Although they don't generally start/run without one.
Old Dec 1, 2016 | 10:40 AM
GEugeneS's Avatar
GEugeneS
Thank you - it was there. Kind of brown in color. I banged the pump harder and it came out. Thanks again!
Old Dec 1, 2016 | 02:10 PM
Rikster-7700
Now go get my pancakes.....
Glad you got it figured out brother...
Old Dec 1, 2016 | 02:56 PM
GEugeneS's Avatar
GEugeneS
Sorry, kinda like Mcdonald's frys, I ate them on the way back.
beefey
13
Nov 11, 2017 07:37 AM
frdf250
Oct 7, 2017 02:49 PM
IHMANKY
Jul 19, 2011 03:23 PM
RÖENTGEEP
24
May 20, 2011 08:27 AM
chris64
16
Apr 12, 2010 02:01 PM
