1959 F250 - cofirming data plate decoding
Old Nov 30, 2016 | 11:01 AM
southbounder's Avatar
southbounder
Hey y'all,
I'm hoping to join your ranks soon as i'm looking at a a 59 F250 to purchase, but I'm having a difficult time decoding the data plate. I've decoded most of it, but the Transmission and the Axle are still not confirmed...
The Trans is "A": while some of the decoders indicate that this should be a number? From looking at listings in the Registry on this subforum though, it appears that "A" is that standard 3-spd that came in so many of these trucks.
Meanwhile, the Axle is "06" - i found a decoder that indicated this is a 2.91:1 - which seems like an oddly high ratio (low number) for a 3/4 ton truck. I didn't find anyone listing an 06 Axle in the registry here after searching a number of pages... Can y'all confirm this axle?
Here it is data plate:
thanks for the help!
~Jake
Old Nov 30, 2016 | 11:48 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by southbounder
The TRANS code is "A" = standard 3-spd that came in so many of these trucks.
The AXLE code is "06" - I found a decoder that indicated this is a 2.91:1
Decoder is wrong! No such ratio ever existed for a Spicer/Dana 60 rear axle.
F25 = F250.
J = 223 1V I-6.
9 = 1959.
N = Norfolk VA Assembly Plant.
11698 = 1959 Numerical Sequence of Assembly.
118" Wheelbase.
R = Red.
F25J = F250 2WD .. 7,400 lbs. GVWR
28K = Assembled October (K) 28, 1958.
A = Ford 3 Speed Manual Transmission.
06 = Spicer/Dana 60 Rear Axle / 4.88-1 / 5,200 lbs. Rear Axle Capacity.
7,400 lbs. Gross Vehicle Weight Rating.
126 net HP @ 4,000 RPM
Old Nov 30, 2016 | 11:50 AM
southbounder
thanks so much, Bill!
Is this decoding information available online somewhere?
Old Nov 30, 2016 | 12:04 PM
NumberDummy
Not that I'm aware of, I used the 1957/63 Ford Truck Parts Catalog to decode it.
This catalog is available on a C/D from hipoparts.com
This truck was assembled in Norfolk VA .. so it was probably sold new in MD, NC or VA .. It was not sold new in AZ
If sold new in AZ, it would have been assembled in San Jose CA
Old Dec 7, 2016 | 04:57 PM
southbounder
I've got another one for you, Bill:
This one is a flatbed, but I'm not sure if it came that way or not.
F25J0H53065
WB: 118
Color: L
Model: F251
Date: 21F
Trans: 1A
Axle: 06
GVW LBS: 4900 (why is this so much less? What is different than the other one?)
DSO: 5054 (What does this mean?)
Thanks so much for your help!
Old Dec 8, 2016 | 02:24 PM
NumberDummy
F25J0H53065 / WB: 118 / Color: L / Model: F251 / Date: 21F / Trans: 1A / Axle: 06 / MAX GVW LBS: 4900 / CERT NET HP: 126 / RPM: 4000 / DSO: 5054
There's no way to know what "back of cab" equipment these trucks came with (if any) until 1972.
F25 = F250.
J = 223 1V I-6.
0 = 1960.
H = Lorain OH Assembly Plant.
53065 = 1960 Numerical Sequence of Assembly.
118" Wheelbase.
L = Dark Green.
F251 = F250 2WD .. 4,900 lbs. GVWR
21F = Assembled June (F) 21, 1960.
1A = Ford 3 speed manual transmission.
4,900 lbs. Gross Vehicle Weight Rating.
5054 = Domestic Special Order number, the truck was ordered special by the original purchaser, not "bought off the lot."
MODEL code defines GVWR
Old Dec 8, 2016 | 02:31 PM
southbounder
Thanks again for the info! The transmission that it's in now is a 4 in the floor - so I'm guessing it's not original. It is a different transmisison code (1A) than the '59 (A) - do you know what the difference between the two Ford 3 Speeds that these represent are?
Why does this F250 has such lower GVWR than the '59 above? Do you know what actually equptment/spec differences this would equate to between the trucks?
Thanks again!
Old Dec 8, 2016 | 03:42 PM
NumberDummy
Thanks again!
The Ford 3 speed manual installed in F100/250's prior to 1963 have a non syncro (crash) 1st gear.
1957/60 F250 2WD's were available w/a 4,900 or 7,400 GVWR
The number of front and rear leaf springs would be the difference.
Old Dec 8, 2016 | 03:45 PM
southbounder
Thanks again! it's a huge help!
Both of these were pre-1963. Does the Parts book differentiate between TRANS "A" and TRANS "1A"?
Makes sense with the GVWR.
Old Dec 8, 2016 | 04:01 PM
NumberDummy
Ford added the 1 to the A .. why I dunno, but the trans is the same.
Alaskan66
Sep 10, 2013 02:45 PM
shillinghillf600
Mar 10, 2013 12:19 PM
Norton72
Offroad & 4x4
16
Jul 12, 2012 05:28 AM
jackndelphine
Feb 6, 2011 02:58 PM
Customcab
Oct 5, 2007 06:24 PM
