Garage Door Opener Programming
I've programmed other cars, jeeps, etc., with those garage doors by:
1. Press learn button
2. Push the button you want to work it
3. You're done
But it doesn't work with my new truck.
One odd thing I see is on the two buttons not programmed for the gate, pressing them makes them blink -- but the one programmed for the gate, pressing it makes a steady light?
I tried programming the garage to the gate button -- just because of the different behavior of the light -- but that didn't work either.
Anybody have the magic secret to make this work?
By the way, I did RTFM, but either I'm an idiot or something because following it didn't work either.
1. Park the truck outside of the garage facing the opening.
2. Clear any existing codes pressing the two outer buttons simultaneously for 20 seconds or until it flashes fast
3. Simultaneously pressed one of the visor homelink buttons along with the button on the handheld remote until indicator flashes fast and release both buttons.
4. Enter the garage and push the learn button on the operator itself
5. Return to truck and push the same homelink button from step 3 and the door began to close and one more press stopped it and one more reversed it.
Bottom line is that pressing the learn button and then the homelink visor will not work on a lot of openers.
Hope this helps.
Hope this helps.
Hope this helps.
This is something that I would to have loved to have found before I spent two hours driving the dog and the wife crazy with the garage doors going up and down trying to program my homelink before finally giving up and putting a garage door opener clicked on the visor. It wasn't until two weeks later when the wife was gone I let the dog outside and went through the trial and error process and finally figured the right procedure out (which again is not what the manual lists).
Any thoughts on getting posts like this readily available? It may be and I just don't know where to look for them so I apologize if it is.
Hope this helps.
Now, to find one more black one for the passenger side...
