Homelink?
Old Oct 15, 2006 | 03:57 PM
automaticj5's Avatar
automaticj5
Homelink?
I have used a few homelinks in my past -- what would be a reason of why the one in my f150 wont connect to my garage door?
Old Oct 15, 2006 | 04:27 PM
f150dude05's Avatar
f150dude05
Just connected my new 07 with my garage door. Seemed more difficult than others. I actually had to connect first with the hand held opener until I got the flashing lights. Then I pushed the learn button on my door controller and pushed homelink for a few cycles of holding in for a couple of seconds each time. Seemed my 05 homelink connected with the learn button alone.
Old Oct 15, 2006 | 04:29 PM
automaticj5
how can you connect with just the learn button? Give me a play by play after I reset the homelink..
Old Oct 15, 2006 | 04:49 PM
GordoPanocho's Avatar
GordoPanocho
You may need to find the manual on your garage door opener. My old style opener/motor merely required that I hold down the remote button while programming the one in the truck. The newer one has a "learn" button on the unit that you have to push before programming the HomeLink.
Old Oct 15, 2006 | 04:53 PM
veronese1's Avatar
veronese1
My wife's 06-has homelink. I cannot get it to sync with my Genie Opener.
Old Oct 15, 2006 | 05:39 PM
automaticj5
mine is genie as well -- but my 03 connected right away!
Old Oct 16, 2006 | 01:03 PM
resopkr's Avatar
resopkr
Follow the distructions in your manual. I set mine up for a Genie and it was a pain in the A$$. Had to press the learn button on the unit and then run back to the truck in time to complete the process. Took me about five times before I got to it work.
Old Oct 16, 2006 | 02:05 PM
sysman_rick's Avatar
sysman_rick
Arrow
The newer Genie openers are digital;the code changes,only the key stays the same.
Old Oct 16, 2006 | 10:31 PM
DASTUD's Avatar
DASTUD
Park it in the garage and then push the learn button. This will save you from having to run back to your truck.
Old Oct 16, 2006 | 11:55 PM
automaticj5
I would if I didnt have this damn camper shell in there! ahaha
Old Oct 17, 2006 | 01:27 AM
the4by4freek's Avatar
the4by4freek
Genie here also. You have, I believe 30 seconds to press the learn button and then the button in the truck. It is a "rolling" code on the opener. If you follow the instructions and maybe have a helper it isn't too bad. I did mine and my wifes in her Sorento in a few trys.
jake00
2015 - 2020 F150
16
Mar 7, 2016 12:32 PM
Fefanatic
2015 + Expedition & Navigator
Jan 7, 2016 09:06 PM
jake00
2015 - 2020 F150
Nov 29, 2015 09:50 PM
richsoucie
Ford Truck Parts for Sale
Apr 27, 2015 02:10 PM
Chillman15
2009 - 2014 F150
Mar 30, 2012 04:09 PM
