Are the front axils on a 1974 f350 1ton and 1976 f350 1ton pick up the same or different?? Yes, yes your right the front beams, are the same or different??
Thank you for your message. Helps a lot. If the length, width and angles are the same, then maybe changing axils and all brake parts to accommodate 1976 brake rotor/hub assembly since 1974 rotor or rotor/hub assembly is no more and can't find good used ones, soooo!? Thanks again.
Hello this is Ric and I am wondering, I have nib 1974 f350 2wd srw rotor and wondering if someone had another or one very close to new. I am willing to buy it. Another thing, I was also playing with the idea of changing the Ibeams from 1974 to 1976 f350 2wd srw, to be able to use the rotor/hub assembly, easier to get. The only thing I can see iS the bushing size. I beleive everything else is the same and minor adjustments can be made, being a welder by trade. Also I can raise the front 1.5-2". Want to try for rotor first. Thanks again, have great holiday.
