Going to try Speedometer #2
Old Nov 29, 2016 | 01:18 PM
D-rat's Avatar
D-rat
When I bought the truck the speedo didn't work (needle spun round and round), but the Odo worked fine. Replaced that with a used unit I found on Ebay...worked for a short period of time and now that speedo is sticking, but again, the odo works fine.
If the odo is working, no way it's the cable, right? Looks like the cable is almost new.
found another used one on ebay...will slap that one in and see if it's any better. While not difficult, I hate blowing the dash apart over and over again....
Is there anything I should be doing to these things before installing (like lubrication, etc)?
Old Nov 29, 2016 | 02:44 PM
mikeo0o0o0's Avatar
mikeo0o0o0
You're correct. If the odometer is working,there's nothing wrong with the cable or the drive/driven gear.
Speedometers are pretty simple inside, a spring, a magnet, a disc and the needle. Not all that much that can go wrong with them.
Usually all they need is cleaning and lubricating. The problem is, while in theory they're simple, they are a little tricky to disassemble and clean/lubricate properly.
I would clean and lube the replacement before you put it in. If you still have the original, you could practice the teardown/reassembly on that one first.
You could also use a drill motor to power the replacement to see if the needle motion and sweep are smooth.
4x4jedi
16
Sep 12, 2011 11:13 AM
barked-knuckles
May 27, 2009 08:45 PM
ericeugunep
Oct 7, 2008 09:58 PM
64fordf100292
Sep 16, 2007 07:20 AM
sigtauenus
Feb 15, 2007 02:22 PM
