Bouncy speedometer??
Old Aug 22, 2011 | 06:52 PM
4x4jedi's Avatar
4x4jedi
Is there a fix for a speedometer that has a bounce or wobble?
When driving between 35-50mph my speedo likes to bounce from 35-50. I have no idea how it works in there but my dash is apart and nows a good time to try a fix.
Old Aug 22, 2011 | 08:33 PM
HIO Silver's Avatar
HIO Silver
My 65 Mustang had the same issue...I replaced the speedometer cable and now all is well. You may be able to get away with lubing it so that's worth a try... ain't nuthin' to lose IMO.
Old Aug 22, 2011 | 10:38 PM
elgemcdlf's Avatar
elgemcdlf
It is the cable. Dry and hanging up on the inside of the housing. Might be able to take it apart (the center usually pulls out from one end) lube it & all be good. If not replace it.
Old Aug 23, 2011 | 04:44 AM
jowilker's Avatar
jowilker
I agree, needs a little lubing.
John
Old Aug 23, 2011 | 05:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Inside the speedometer cable's housing is a woven steel core that is supposed to be lubed every so often, but many people are unaware.
When the lube dries out, the speedo's needle bounces, and...sooner or later...the steel core binds up inside the housing...and snaps.
Autoparts stores sell a 'universal' woven steel core kit. You cut it to length, coat it with a fine film of white lithium grease or graphite, install in the housing.
Old Aug 23, 2011 | 08:13 PM
CougarJohn's Avatar
CougarJohn
Bill, after you cut the cable to length, don't you need to make the round ends square to engage the speedo and trans? How do you do it? With a hammer? I have the same problem, grease doesn't fix.
Old Aug 24, 2011 | 01:34 AM
NumberDummy
Adapters to do this come with the core kit.
Old Aug 24, 2011 | 01:54 AM
ford390gashog's Avatar
ford390gashog
The cable just pulls out of the tube. I pull mine out and add about 1 oz of Ford moly grease into the tube with a grease gun and a needle.Then slide the cable in and slide it back and forth to get the grease through all parts of the tube.
Old Aug 24, 2011 | 11:26 AM
4x4jedi's Avatar
4x4jedi
I'll try some grease. Ill have it all apart this weekend again.
Old Aug 25, 2011 | 12:40 PM
tmcalavy's Avatar
tmcalavy
This thread is making me curious-er and curious-er. Good info, but I haven't crawled under the 69 F250 to have a look...so it's hard for me to visualize. I can pull the speed cable at the gauge and at the tranny...pull the cable out, smear it with white grease...and then put it back, right? Or do I have to deal with special cable ends at both places? I know there's a speedo gear in the C6, but I've never seen how/where the cable connects to the gauge. Can someone set me straight?
Old Aug 25, 2011 | 03:40 PM
NumberDummy
The cable ends will be on the original woven steel core you remove from the housing.
If the woven steel core has snapped, the autoparts store woven steel core kit includes 2 cable ends.
Since the kit is a universal fitz-all, the cable has to be cut to length...then the cable ends are installed.
C6: The replaceable speedo DRIVEN gear is at the end of the cable. The speedo DRIVE gear is made as part of the output shaft, cannot be replaced by itself.
Old Aug 25, 2011 | 06:28 PM
tmcalavy's Avatar
tmcalavy
So how does the housing come apart to get the cable out?...or does this require replacement with the universal kit?
Old Aug 25, 2011 | 07:14 PM
NumberDummy
The autoparts store universal 'fitz-all' kit is just the woven steel core and the cable ends, does not include the housing. This kit fits myriad different vehicles, not just Fords.
The woven steel core is removed from the housing to lubricate it, removed if it has snapped in two. The last time I removed the core from the housing, Nixon was prez, so I'm a little foggy on which end it comes out.
And since it was a 1939 Packard I was working on, if I guessed which way...Ford may be different.
Old Aug 29, 2011 | 04:28 PM
FECruzer69's Avatar
FECruzer69
I just lubed the cable in my other project. The cable core will come out from the speedometer end of the cable.
Old Sep 11, 2011 | 02:12 PM
Dixiesweep's Avatar
Dixiesweep
speedo still bouncing
I replaced the cable and it still bounces like it did before. Mine is a 91 Ford F150 4x4 with a 302. It has the aod transmission. Could it be the cluster..also my tach needles stays at 4000 all the time..thanks..Joe
