'55 239 2 barrel, 4 speed dump truck
Whats up guys, just bought a '55 f500 dump truck, starts great, as you give it a little gas, it kinda studders, then picks it back up. the little studder lasts about a second or two, just long enough to make you think its going to die. I'm sure the air adjustments are out of whack, its been a long time since I've adjusted one, would one of you guys be so kind as to run through the process for me? thanks and glad to be a member!
I don't know enough about the earlier Y's to help you. I do advise that you get a shop manual for the truck. It should have that procedure outlined.
The truck is '61 years old now which means anything could have been done ot it by now, so I do have one question. Does it have an original style 2 barrel, which mounts to the intake with 3 bolts or is it a more modern one which mounts using 4 bolts?
Check the block ID to find out what you have.
Here's a great site for determining what your engine is!
TECHNICAL
Cheers,
Rick
chappys4life
30
12-19-2014 09:32 PM
Outlaw56
23
05-24-2014 11:07 AM
morty
05-25-2003 07:08 PM
