Help with oil consumption
Old Nov 29, 2016 | 05:16 AM
G3angler's Avatar
G3angler
I know I've complained about oil consumption before on my 12' 5.0 with 42 K. I've kinda come to terms with it and figure not much I can do ? Next oil change I want to try to improve it. Checked it the other day and has used approx 3/4 of quart in 2200 K. I've read other guys post on this forum talk about improving consumption by switching brands and trying different viscosity. I'm using the recommended Ford 5/20 synthetic now. Any ideas guys ??
Old Nov 29, 2016 | 05:40 AM
glockholiday's Avatar
glockholiday
I would definitely switch to 5W-30 and try Motorcrafts synthetic blend over their full synthetic.
Old Nov 29, 2016 | 07:10 AM
ubereal2's Avatar
ubereal2
I've lucked out and not going through any oil between changes. But I'm also sticking with a Synthetic blend, 5/20.
Old Nov 29, 2016 | 07:41 AM
brokenleg's Avatar
brokenleg
Is the engine ticking??
Old Nov 30, 2016 | 01:52 PM
David W Jones's Avatar
David W Jones
I use 5w-20 Mobil One XP in my 2012 5.0 and run a 10,000 mile OCI. 96,500 miles. I'm sure it uses some between changes but precious little.
Old Nov 30, 2016 | 02:42 PM
tyoder's Avatar
tyoder
I'm using 5/30 Penz. Platinum. No consumption issues here .
Old Nov 30, 2016 | 06:55 PM
meborder's Avatar
meborder
Currently having good luck with Mobil 1 5w30 High Mileage.
Also had good luck with Trop artic 5w30, Castrol edge 5w30 black bottle and Castrol edge 5w30 EP gold bottle
Had terrible luck with Trop artic 5w20, Napa synthetic 5w20, and Pennzoil platinum 5w30.
All the good ones consume about 1qt/4000+ miles, all the bad ones were 1qt/2000 miles.
YMMV
Old Dec 3, 2016 | 05:18 PM
eriebasin's Avatar
eriebasin
FWIW, I use Royal Purple or Mobile One (this last time because I was far from home), both full synthetic. The truck uses absolutely NO oil. It is on the exact same X on the dipstick every time I check. I have 39,8XX miles. I feel like I lucked out too. I've never had a vehicle not use some.
Old Dec 3, 2016 | 06:18 PM
unibody62's Avatar
unibody62
I think that the high end full synthetics, such as Royal Purple, Mobil1, and Amsoil, are your best bet for maintaining a full crankcase. I don't have a 5.0, so I can't vouch for any of them in this situation, but I've had sucess in other engine cutting down usage.
bryanlindborg600
Feb 8, 2015 06:12 PM
soupy1957
2009 - 2014 F150
31
Jan 5, 2013 05:15 PM
NS F250
Apr 20, 2007 03:39 PM
jboard
Jan 11, 2007 07:54 AM
jman724
Oil & Lubrication
32
Jan 17, 2006 09:00 AM
