Replacing Upper & Lower Balljoints on EX
Old Nov 28, 2016 | 12:48 PM
Jkelley's Avatar
Jkelley
After replacing my Wheel Bearings myself (with help from this Forum ) took the Excursion in to have a The front end aligned it checked out fine, But now Hibdons is saying I need upper and lower Ball joints replaced on both sides my 2001 Ford Excursion 2wd gave ne an Quote of $800.00 ..I found a write up on do it yourself , but was for a 4WD ..How hard is this procedure ? And does anyone have a Write up to share fir a 2wd .? Thanks everyone
Old Nov 28, 2016 | 01:37 PM
Don Naslund's Avatar
Don Naslund
Have you checked youtube yet? They usually have everything on there.
Old Nov 28, 2016 | 02:21 PM
Stewart_H's Avatar
Stewart_H
The tech folder is your friend.
Stewart
Old Nov 28, 2016 | 03:22 PM
Jkelley's Avatar
Jkelley
Found a Video and Found some good stuff in the Tech Folder I can use.. Techs at Hibdon's said the Wear is Marginal on both sides..
Old Nov 28, 2016 | 09:17 PM
Borderline Homeless's Avatar
Borderline Homeless
I did the uppers and lowers in an afternoon with help from the you tube. Not that bad of a project. Going to now work on blown out spark plugs!
Old Dec 1, 2016 | 11:37 AM
stpete's Avatar
stpete
Look at the ball joints in the steering linkages while you're at it. Also look at the bushings in the twin i-beam (more youtube vids for you). I've been at this for a while and am still trying to stop the wandering. Would've been much easier if I had done it all at once instead of taking it apart over and over again to put in more $20 parts.
halfhitch
Sep 11, 2016 05:18 PM
Shwan_89HD
Jun 7, 2013 08:38 PM
labman1014
Sep 21, 2010 08:22 PM
Lewis50
Aug 10, 2007 08:07 PM
BlackF350rocks
Jun 4, 2007 09:20 PM
