Sponsored by: Real Truck
Upper & Lower Ball Joints
Old Jun 4, 2007 | 05:39 PM
BlackF350rocks's Avatar
BlackF350rocks
Has anyone out there had to replace their Upper and Lower Ball Joints yet on a 2001 F-350 SDD? I had estimates around $750.00. Is this reasonable?
Old Jun 4, 2007 | 05:43 PM
Beerstalker's Avatar
Beerstalker
Check the Tech Folder.
https://www.ford-trucks.com/forums/3...ll-joints.html
Old Jun 4, 2007 | 05:44 PM
boxcar1974's Avatar
boxcar1974
I just paid $500 for right sides upper and lower along with repacking both side needle bearing.
The parts alone are about $175
Old Jun 4, 2007 | 05:47 PM
BlackF350rocks
The DEALERSHIP says I need it done on both sides. Tires are NOT wearing odd thou
Old Jun 4, 2007 | 06:09 PM
boxcar1974's Avatar
boxcar1974
I had all four replaced in the past year. Never did the truck show any sign of a problem. The was no wander, pull, chunch, tire wear, or any other symptom. The way I found was jacking up the truck and with a long bar and a block of wood pry under the tire and watch to see how much play is in the joint. If you can see it move......time for replacement.
I would not recommend FORD replacement ball joints. Get a good quality regreasable replacement.
I have moogs on the lefts and tried to have moogs on the right but the joint was too darn right and the truck was a bear to drive and ended up putting Fords back in on the right.
Old Jun 4, 2007 | 07:27 PM
CruiserClass's Avatar
CruiserClass
The Moogs loosen up after a couple of hundred miles. My truck felt tight and had some wander until they settled down a bit.
Old Jun 4, 2007 | 09:20 PM
99f350sd's Avatar
99f350sd
$500.00 for both sides is a fair price plus materials... Moogs are lifetime warr..
Dick
