Tires that'll fit
Tires that'll fit
2015 CC F250 Platinum 4x4. I will be needing tires soon and will need to get some A/T tires as I will be off road as much as on the highway due to my job. I am looking for recommendations for tires and possibly a mild lift or leveling kit. I will be using my stock rims as well. With so many aftermarket options out there and tire options I figured i would come here for advice first.
I would go with the 295/65/20 if your looking to max out the stock wheel. This size has the highest payload and is rated on the factory width 8" wheel.
Here's some pics and link:
https://www.ford-trucks.com/forums/1...95-65-20s.html
I run 37x13.50x20 Toyo RT on my leveled truck. I ran 315/60/20 (35x12.50) Toyo MTs when my truck was stock. A friend of mine runs 35x12.50x20 Toyo RTs on his leveled truck. Both rub the radius arms a bit. Both are used to tow 5th wheel trailers. Both are on stock wheels.
FX4CHLTNC
Jul 14, 2005 08:24 AM
