1978 - 1996 Big Bronco
Problem with eec testing
Old Nov 27, 2016 | 02:12 PM
Iron Port's Avatar
Iron Port
When I tried pulling code for my 1993 ford bronco it would no do anything. I put a wire in the second top pin on the connector to the jumper pin. when I turn the key I just get a check engine light. Please help!!!
Old Nov 28, 2016 | 11:52 PM
Encho's Avatar
Encho
The Southernmost Mod
Are you 100% sure you're following the procedure?.
Old Dec 3, 2016 | 06:39 PM
jowens1126's Avatar
jowens1126
try running a wire from the STI (Self test input) Directly to the negative pole of the battery. then turn the ignition to ON but not running and it should go into diagnostic mode. I have seen several broncos have problems with the diagnostic ground circuit not working on the connector itself.
OceansideAirbrush
Dec 2, 2016 07:28 AM
scottddove
Jul 31, 2015 02:02 PM
navigatorstang
20
Feb 21, 2011 04:58 PM
77300i6
1983 - 2012 Ranger & B-Series
20
Oct 22, 2008 06:55 PM
mike L
Sep 15, 2004 10:30 PM
