Wont start without starter fluid or plugged in
Update
I tried the arcing the glow plug relay with no luck. i did find it was humming for a go while too. i found the clicking is my ac pump kicking on and off with the ignition being turned on. my ac kicks turns on and off randomly with a/c off and heat blasting. but thats a whole different thread.
i did remember when i was putting the glow plug relay in i tightened one of the smaller studs too much and stripped what ibthought was the nut, i didnt attempt to take it off i just put an extra nut from the old solenoid over it to keep it snug.
could i have broke the post or GPR?
i think ill just throw new glow plugs, new UVCH, and new GPR in, and new valve cover gaskets....and this time be more careful with the New GPR.
That way i know its done...and if it still dont work ill assume its my injectors then?
thanks.
thanks.
I haven't read the entire thread, but if you're bridging the two big posts for like 15 seconds and then you go to start your truck and it still isn't starting then you either have;
- Bad Glow Plugs
- Bad UVCH
- Bad/corroded wires leading from GPR to glowplugs.
THIS MAY BE VERY RELEVANT TO YOUR SITUATION!
If you have your heater/AC/Defroster/Vent controls turned off, and the AC Pump is kicking on and off when you turn the ignition on, you have a faulty ground wire/connection! Check your ground cables, both ends.
Received 3,113 Likes
on
If you're using the MIX or windshield defrost position, the A/C compressor will energize with the key in the ACC or RUN position.
but it has also (sometimes does it, sometimes not) kicked in and out at idle with the truck running too.
but it also clicks twice when i turn the key to acc to warm the gp's
I thought i fixed it
Well i think i need some new batteries, terminals and wires. But besides that... THIS GOD DANG TRUCK STILL WONT START IN THE COLD! FYI ITS -20 HERE!!BRRR!! havnt tried it while plugged in yet since i changed my glow plugs, gpr, uvch, and checked everything was working before putting the covers back on. But besides my crap batteries...while on the 200amp charger...it wont pop off... even tried starter fluid. Not even a putter. However, After i just sat with the key turned for about 40 seconds it started to chugg then popped off. Blew blue and white. I didnt wait for it to fully warm because i was just moving it 15ft into my heated garage to do some unrelated work to it. But after about 1 minute it was still blowing blueish white. I CAN ONLY ASSUME THIS IS AN INJECTOR PROBLEM (BESIDES MY JUNK BATTERIES AND TERMINALS)? AM I CORRECT OR WRONG?
Even if you broke the stud off inside of the solenoid itself, bridging the two big posts with a screwdriver or something along those lines would jump the power across and activate your glow plugs.
- Bad Glow Plugs
- Bad UVCH
- Bad Glow Plugs
- Bad UVCH
#28
on
first thing you need to do is get good batteries and cables in it. glow plugs draw A LOT OF POWER
close to 200 amps just for the glow plugs. then you add in the starter, and poor batteries ain't gonna cut it.
the GPR buzzing could very well be the battery charger not being able to supply enough power for everything.
the smoke on a cold engine at -20 degrees would not bother me
#29
Id not suggest shimming them yourself based on this thread.
With a proper running glow plug system and good injectors your truck should start well into the negatives. It was -18 this morning, and 5 year old plugs and relay it fired right up, sounded like chit, but it fired up, and that's with two injectors that stick when cold until you get on it down the road. With charged batteries, count to ten after the wts light goes off, and crank.
outdoormaniac
11-30-2009 11:56 PM
