Sponsored by: Real Truck
Convert to composite HL
Old Nov 26, 2016 | 07:32 PM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
I know I've seen this info before but just can't seem to find it, my nephew has an 02 SD and wants to change the standard headlights to the composite. A side from the lights and the HL plugs is there anything you need to change like a header panel or such or is it a straight up swap? Any info you all can give would be great... Thanks
Old Nov 26, 2016 | 09:02 PM
Mike189677's Avatar
Mike189677
There is an adapter plug on the lights from the factory that goes from 9007 the bulb that the compsite lights use to which ever # the sealed beam is hb4 maybe can't remember off the top of my head. The header panel shouldn't need anything done to it unless you change to the 05-07 lights which I would recommend then you would need a different adapter that goes from 9007 to 9008 less than $10 though.
Old Nov 26, 2016 | 10:22 PM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
Thanks, If you go to the newer lights do you have to modify the header or just change it also?
Old Nov 27, 2016 | 12:45 AM
Mike189677's Avatar
Mike189677
You have to do one or the other either cut it or replace it with the 05-07 header panel. Cutting its not a big deal takes about 30 min with a Dremel and cutting bit is what works best. I have a good write up saved I can link if you and your nephew deicide to go to the newer lights and want it.
Old Nov 27, 2016 | 09:48 AM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
Yeah link it here so I can check it out before we decide which lights to use. Thanks a lot for your help.
Old Nov 27, 2016 | 02:54 PM
Mike189677's Avatar
Mike189677
No problem here you go.
?99-?04 Superduty To ?05 Headlight Conversion - Ford Diesel Performance Parts Blog
Old Nov 27, 2016 | 03:50 PM
ligito's Avatar
ligito
Do these lights fog over any less than the stock '99 headlights?
Old Nov 27, 2016 | 03:57 PM
ligito's Avatar
ligito
Would buying this panel make more, or less work, than trimming the stock panel, on a '99 F250?
Mount Panel for 2005 Ford F-250 Super Duty|6C3Z-8A284-A : Genuine Factory OEM Parts & Accessories | TascaParts.com
Old Nov 27, 2016 | 06:25 PM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
Originally Posted by Mike189677
Perfect, thanks again for your help, it's much appreciated
I don't know what you mean by fog over but cutting is a money saving way to go about it.
Old Nov 28, 2016 | 11:51 AM
ligito's Avatar
ligito
My lights are cloudy (fogged over).
Ford did a detail job and cleaned off the headlights but in only
a couple of months, they were cloudy, again.
Do the composite lights get cloudy?
Old Nov 28, 2016 | 02:42 PM
Mike189677's Avatar
Mike189677
One they fog up the only real long term solution is new headlights and the 99-01 lights are the worst of the worst in regards to out put that being said none of them are great until maybe the 17's with the LEDs. The 02-04 lights will drop right in no modification required 05-07 you will either have to cut your header panel less work than putting in the 05-07 header panel and free if you already have a dremel or similar cutting tool.
Old Nov 30, 2016 | 02:06 PM
ligito's Avatar
ligito
What do the 02-04 lights look like?
Would they be a benefit?
Are the 05-07's better?
Old Nov 30, 2016 | 02:53 PM
ligito's Avatar
ligito
Would these do the job? https://www.1aauto.com/ford-headligh...=845301&y=1999
Old Dec 8, 2016 | 11:25 AM
ligito's Avatar
ligito
Bump ?
Dawgfever
Jan 2, 2019 10:58 AM
GORDEN1234
2015 - 2020 F150
Mar 6, 2017 08:13 PM
Bruinzfan
Mar 30, 2014 10:26 PM
Michigan Rick
Aug 24, 2010 09:18 AM
90XLT_Silver_Bullet
Aerostar
Mar 22, 2004 08:48 PM
