Clutch Fork
Old Nov 26, 2016 | 06:47 PM
BGF100's Avatar
BGF100
Clutch Fork
Hi,
I have seen the article https://www.ford-trucks.com/forums/1...llhousing.html.
I have a 78 F100 Cleveland V8.
I have been having problems with my clutch.
The pedal presses down gets stiff for an instance and then goes free again.
It puts quite a bit of stress on the cluth system when it goes stiff and I have to really press down to get it inot gear. Too much so, it would be no good driving like this.
When I took a look at the fork set up when the master cylinder had originally gone two months back. I disasembled the slave cutch set up and the fork was easily puled out and put in into the bell housing. I noticed the fork had a hinge type part on it with two holes. Like shown in the first photo. The part is attached to the bell housing. However this part was attached to my fork.
Hope I am not going to have to revove the bell housing to repair the situation. Anyone had a similar experience or can help? Thanks,
Old Nov 27, 2016 | 01:26 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by BGF100
Hi,
It puts quite a bit of stress on the clutch system when it goes stiff and I have to really press down to get it into gear. Too much so, it would be no good driving like this.
When I took a look at the fork set up when the master cylinder had originally gone two months back. I disassembled the hydraulic slave clutch set up and the fork was easily pulled out and put in into the bell housing. I noticed the fork had a hinge type part on it with two holes. Like shown in the first photo. The part is attached to the bell housing. However this part was attached to my fork.
There's nothing we can do for you since you're in Australia. F100/350's sold "Down Under" are totally different mechanically than US/Canada.
In the US/Canada, the 351C was only installed in 1970/74 Ford/Merc Passenger Cars/Ranchero's.
No 1970's US/Canadian F100/350 had a hydraulic clutch. It was introduced in 1983 F250/350 6.9L diesel and 460, in 1984 F150/350 & Bronco 300/302 (except F350)/351W
76WYOF250
Jul 10, 2014 02:12 AM
brokeasajoke
May 18, 2014 09:27 PM
FLHermit
Jul 7, 2011 06:08 PM
windsorfordever
Sep 2, 2010 11:34 PM
gdaf
Oct 14, 2001 04:53 PM
