T18 hydraulic clutch conversion?
Old 08-31-2010, 10:13 PM
windsorfordever's Avatar
windsorfordever
windsorfordever is offline
I have a T18 borg warner tranny with no bellhousing, it had the mechanical clutch in it. It's going in a 92 F150 with a 302, how do i go about converting it to a hydraulic clutch? By the way I had an E4OD in it so i'm sure i'll need a special clutch pedal, anything specific?
Thanks for any information, for how lost I am right now everything will help tons!
Old 09-01-2010, 04:52 AM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
The easiest way would probably be to find a similar truck in a junkyard and get the pedal assembly, hydraulics, and bell housing.
Old 09-01-2010, 04:16 PM
windsorfordever
Alright, will the mount holes for the slave be on the bell housing or will i have to, (or be able to), tap new ones in the tranny casing?
Old 09-01-2010, 07:40 PM
EPNCSU2006's Avatar
EPNCSU2006
If it's like the external slave on my '87, it will mount to the bell housing.
Old 09-02-2010, 01:25 AM
polarismuddman's Avatar
polarismuddman
polarismuddman is offline
It is an external slave...and only a pedal assembly from a gen 9 (92-96) will work for ya.
Old 09-02-2010, 10:30 PM
windsorfordever
ok, a friend of mine has an 85' 2WD F250 sitting behind his shed and it has the external hydraulic clutch, I don't know exactly what tranny it is but it's also a 4 speeed manual, any chances the bell housing and clutch would work me? The engine is a 351, I think it's a cleveland, but i'm not positive.
Old 09-02-2010, 11:34 PM
polarismuddman
Doubt it's a cleveland...unless a 351 Modified slipped by...it's most likely a Windsor in which case the answer to your questions is simply, yes. You will need a flywheel specific to your truck though.
56f1000
01-31-2017 07:09 AM
1956_F100
04-28-2016 11:51 AM
Tuttle69
04-07-2016 10:48 PM
Elwood72
04-09-2011 08:21 PM
GUERILLA
05-08-2009 09:20 AM
Quick Reply: T18 hydraulic clutch conversion?
