Leveling Kit Components
Old Nov 26, 2016 | 10:03 AM
achec's Avatar
achec
So I ordered a Kit from Wicked customs and it includes:
Track Bar relocation bracket
Radius Arm drop brackets
Front Factory Shock Extensions
I seen on Ready lift kits they come with
Brake line drop bracket
Bumper extension
and sway bar drop
do you guys with the experience think i should buy the extra components or is what wicked kit enough?
thanks
Old Nov 26, 2016 | 04:04 PM
UGA33's Avatar
UGA33
How much are you planning on lifting it?
Old Nov 26, 2016 | 04:56 PM
achec's Avatar
achec
3.5 inch spacers
Old Nov 26, 2016 | 07:37 PM
UGA33's Avatar
UGA33
3.5" is pretty high. Definitely will need to address the track bar and radius arms. Not sure on the brake lines. Probably wouldn't be a bad idea to lengthen them.
Are you trying to do it on a budget or is the sky the limit?
Old Nov 26, 2016 | 07:40 PM
oklarado's Avatar
oklarado
I'm not familiar with Fords, but in most offroad trucks if I was going 3.5 I'd switch to new coils and do it right.
Old Nov 26, 2016 | 07:43 PM
UGA33's Avatar
UGA33
I was gonna mention doing it this way also with some adjustable 3link arms versus drop brackets. Then add an adjustable track bar.
Old Nov 26, 2016 | 07:46 PM
UGA33's Avatar
UGA33
Old Nov 26, 2016 | 08:15 PM
Ricohman's Avatar
Ricohman
2 inches or more will require ball joint alignment cams.
That is if you want to preserve the caster specs.
achec's Avatar
achec
yes 3.5 is high but i been looking at some pics online and it looks really good.
look up fontenonts diesel performance on Facebook as well as wicked customs Facebook and IG
the 3.5" level looks sweet.
i have the
all coming
now i think i will do the brake line and sway bar adjustments too.
i will probably change the shocks and more if needed if drivability feels compromised after install. but as of now what i mentioned is all thats being changed
and of course tires
toyos not sure of rt's or at's yet also deciding on 37x12.50 or 295 65 20 keeping stock platinum wheels.
thanks guys for input
Old Nov 26, 2016 | 08:20 PM
achec's Avatar
achec
Some pics that pushed me to get the 3.5" kit versus 2.5"
All have 37" tires i believe besides the white platinum he's running 35s
so mine will look identical to that if i go 35s
None of these trucks or pics are mine all off the web
Old Nov 26, 2016 | 09:45 PM
Ricohman's Avatar
Ricohman
Put a trailer on those trucks and they will look like a 50's lead sled with its nose in the air.
Old Nov 27, 2016 | 12:13 AM
achec's Avatar
achec
O ok i didn't know the companies won't be making airbags.
BigBlackF-250
Feb 10, 2016 12:51 AM
LaredoF350
Mar 1, 2011 10:05 PM
superduty4x4
Aug 4, 2008 04:09 PM
RyanGruhn
1978 - 1996 Big Bronco
Apr 21, 2004 12:05 PM
ke6jcf
Nov 5, 2002 03:54 PM
