After market head unit
Old Nov 25, 2016 | 01:43 PM
Telling Zachary Otis's Avatar
Arrow After market head unit
I just recently bought a 1975 f250 high boy everything as far as I have ventured so far is as it came off the lot in 1975 other then the angina and possibly the transmission. I plan to do a full restore stripped all the to frame re wire and rust proof everything and replace whatever needs replaced it does currently have a 390 4bbl engine with for spead manual transmission, that I do plan to replace with the more appropriate 360 2bbl that would have been found on it originally. But that will be my final step. I plan to keep everything as original as possible but would like to wire separately and place under the seat a head unit and speakers so I can enjoy more modern amenities such blue tooth and aux. what would be the best way to go about doing this while leaving the factory system still fully operational. Also this is my first full restore and first time working on anything quite this old, so I am open to any advice and tips, and changes I might want to make to make it a lasting and enjoyable ride, as it will be driven quite often once it's done I also have a 1979 f150 explorer package I will be working on next , any major differences I should expect? Would it be smarter to take the two and make them one?
Old Nov 25, 2016 | 01:55 PM
meangreen92's Avatar
meangreen92
I always knew that these trucks had a heart!
You would wire up the new head unit and speakers and amp as a stand-alone system. Your power connections would be the only intrusions to the truck. Are you planning on pulling the radio from under the seat when driving? You would want a good wiring harness to stand up to that repeated movement, and definitely some good strain-relief for each end of the harness. I plan to mount a radio under my dash, so as to avoid cutting my radio-delete dash bezel.
Welcome to the site, and we like pics here..
Old Nov 25, 2016 | 02:06 PM
Have the head unit stationary probably snug between the bench and the tranny hump, then just run all the music through my iPhone. With a speaker under each seat maybe even smaller on or two in the back of the seat, but I'm not sure how that would sound bouncing of the gas tank, especially once it gets low. I just want it all to be out of plain sight.
Old Nov 25, 2016 | 02:07 PM
krazyness's Avatar
krazyness
Somebody else will have to chime in with brand/website (or you can try Google) but there are aftermarket radios that retain the vintage look that will fit into the factory location and look era correct but will give you the modern day amenities that you're looking for.
Also, why downsize to a 360? The 360 and 390 are technically the same engine, just different stroke.
Old Nov 25, 2016 | 03:27 PM
I'm not interested in something that looks like a date period stereo no offense. It has the original radio that came in it and it works perfectly fine and I love it even though I'll probably never use the thing. I got it to restore to as close to original as I can get it. I'm in no rush. I'm currently waiting for the build sheet for my vin to see what it exactly and I'll go from there. But at $600 for complete 75 4x4 with a mint condition interior (can't say the same about the body) I want to down size to the 360 because as far as I have read the 75 f250 only came with the 360 and the 460 engine options. Please correct me if I'm wrong. But it could be the 360 could be a 460 I'm not entirely sure how to tell the difference
Old Nov 25, 2016 | 03:51 PM
meangreen92
I think the High Boys only came with the 360 and the 300 straight six. A 360, being an FE, will have the inboard valve cover bolts threaded into the intake manifold.
Old Nov 25, 2016 | 04:21 PM
I'll have to look. My uncle who I bought it from said he was pretty sure it was the 390 or the 460, something about the short little hose running out of the top the water pump into the engine. I don't know anything about that though. I havnt even brought it home yet. Just went and looked at it and bought. I've only ever worked on my 88 f150 and I've damn near rebuilt the thing
Old Nov 25, 2016 | 04:52 PM
LIL LU's Avatar
LIL LU
Agreed that is the route I am going also. By the time I rig up a modern system space and convenience are compromised and a fire is imminent if it isn't done correctly.
I wanted an equivalent to a Kardan Harmon 8.4 with the fancy display touchscreen like my car has...but wait.. I cant see it under the seat or in the glove box yet alone touch it to activate programs..Voice command sure isnt going in my truck lol
Old Nov 25, 2016 | 06:54 PM
krazyness's Avatar
krazyness
Well, you can't tell the difference between a 360 and a 390 just by looking at it. You would have to measure the stroke to be sure. A 460 is a completely different engine series which makes it easy to tell the difference just by looking at it (if you know what to look for). As far as factory spec engine, assuming it rolled off the line with a front axle (4x4) its gonna be a 360. No 4x4 got a 390 from the factory but, since they are the same engine, its very easy to convert a 360 to a 390 or vice versa.
I understand your desire to keep everything original but if you're gonna put an aftermarket stereo in anyway, I don't see the harm in using one of the "classic" styled modern radios to keep things more simple. Too each their own though.
Old Nov 25, 2016 | 08:08 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Put the head unit in the glove box, outa site, outa mind. Speaker in the doors.
Jeeeppy
17
Jan 8, 2016 08:30 PM
Gary E
Oct 17, 2015 03:48 PM
Larzon
Dec 12, 2011 11:39 PM
GShelton
Mar 19, 2007 07:09 PM
3ValveV10Harley
Sep 26, 2006 08:14 PM
