Heater is barely heating
Old Dec 23, 2016 | 10:54 AM
  #31
WatsonR's Avatar
WatsonR
Maybe.... turn the heater on hot and fan on high. Remove the degas cap and get the truck up to temp. Since there is not valve in place on the heater core line, water should flow freely and it should get pretty hot... run the truck until you see good flow in the degas tank... let it run a bit, that should clear the air, if any. Just make sure it hits full temp or the t-stat won't open. You could wait until its at full temp and then carefully vent the cap, then watch the flow as well.... don't burn yourself!
You could add a small section of clear tubing to see flow as well. A couple pieces of brass 5/8" pipe, 4 hose clamps and a 6" piece of tube.
Old Dec 23, 2016 | 11:01 AM
  #32
Norma stitz's Avatar
Norma stitz
That's a good idea with the clear tube. As for running it a bit to get it up to full temp, that would never happen in my driveway, at least not in an 8 hour day. This thing requires actual driving to get it up to 200°. Very cold blooded!
Old Dec 23, 2016 | 11:04 AM
  #33
WatsonR's Avatar
WatsonR
what temp is it getting to? Your T-stat bad?
Old Dec 23, 2016 | 11:06 AM
  #34
Norma stitz
NEw mishimoto, finally settles on 199-210° unless I go down a big hill and then it falls down. Just takes a long time to get up there.
Old Dec 23, 2016 | 12:32 PM
  #35
jetjockey99's Avatar
jetjockey99
With the miles on your truck you could have a heater core that has a film on the inside that flushing does not remove. I was a Certified Master Tech for over 45 years and every once in a while I would come across a core that no matter what you did it would not transfer enough heat to deliver a warm interior. The only solution was to put in a new core. I was able to get a couple to work by running them through a boil out tank, but at that point it makes more sense to just replace it, plus the chemicals in a boil out tank weakens the brass or aluminum in the core and who knows how long before it starts to leak. One test you can do is to bypass your core and put a foot long piece of copper tubing in the bypass and run it until up to temp and see how hot the tube gets, it may be too hot to hold onto, if so replace the core, if just warm you have other issues.
Old Dec 23, 2016 | 03:37 PM
  #36
87crewdually's Avatar
87crewdually
A sheet of cardboard slides in front of the radiator nicely. That along with high idle will bring it up to temp.
Old Dec 23, 2016 | 04:02 PM
  #37
WatsonR's Avatar
WatsonR
^^^ right here^^^ works like a champion, use 1/2 sheet if it's too hot.
Old Dec 23, 2016 | 05:04 PM
  #38
Yahiko's Avatar
Yahiko
The plastic sign board is also nice because when it gets wet you don't
get what looks like soggy oat meal.
Old Dec 24, 2016 | 05:26 AM
  #39
Per4mance's Avatar
Per4mance
Pull the stat and make sure it's seating in the housing. Just went through that with a new stat that I had from Mishimoto. It was old stock from when they first came out. I had to make the hole in the housing a little deeper
Old Dec 24, 2016 | 07:52 AM
  #40
TooManyToys.'s Avatar
TooManyToys.
Hadn't gone through this thread until now. My '03 Lariat bought in South Jersey (Vineland) never had the valve. It's a curious mix of what vehicles it was installed in.
If the blend door is fully functioning, and no debris blocking blower flow, I'd be thinking of the T/S not fully seating, since with its closure there is a better tendency for volume through the heater core. My view is towards your comment of the truck being being cold blooded.
IMO, the heater performance is proportional to the radiator temp in my truck, so winter always gets the plastic sign in front of the radiator. Actually, I have three sheets, so depending on the avg temp, one, two, or three get installed depending on the temp of the time frame. If my truck wasn't hold down the driveway it would be running one sheet right now.
Old Dec 24, 2016 | 08:04 AM
  #41
BLADE35's Avatar
BLADE35
That vac line isn't plugged in right so it leaks
Vac press controls the blend door
fix the obvious first or is that where the vac line runs when there is No Valve??
seams to reason if it had a Vac Line then at some point it had a Valve
previous own must had same problem and deleated it thinking it impeded flow
your not saying its stuck on defrost so somethings a miss
Old Dec 24, 2016 | 08:30 AM
  #42
TooManyToys.
I've owned my truck new off the lot, never had the valve and the vac line get plugged into the dead ended stud on the heater box.
Old Dec 24, 2016 | 12:23 PM
  #43
BLADE35's Avatar
BLADE35
THANKS for your reply Jack
Old Dec 24, 2016 | 12:31 PM
  #44
TooManyToys.
Yeah, it's weird what got the valve and what didn't, so just when you think you have it nailed, there's my truck. Not by trim level nor by region. I ended up putting a manual valve in incorporating the coolant filter.
Old Dec 24, 2016 | 11:08 PM
  #45
jdw1's Avatar
jdw1
Impeller slipping on water pump shaft and not circulating enough coolant?
And didn't the cab heaters act strange when oil cooler is restricted/ plugged on the coolant side?
If you bypass the heater core and put a clear piece plastic hose in between you could possibly see how much volume of coolant is flowing, just leave the degass bottle cap off as to not build any pressure in coolant system.
