Questions about EGTs
Old Nov 26, 2016 | 09:40 AM
  #31
RV_Tech's Avatar
RV_Tech
The reviews on the S&B do suggest more noise.
Old Nov 26, 2016 | 10:27 AM
  #32
Tugly's Avatar
Tugly
At the time... alleged 80 HP tune on stock truck with 4" downpipe and exhaust (it behaved more like a 100 HP tune). I had the red line mod, and I could just reach 32 PSI boost in spurts - but 28-30 PSI boost was sustained.
The Filter Minder was getting sucked in with a clean filter, and I had already changed the Filter Minder to the old style. I cut a hole on the fender side of the housing and this helped - but it didn't completely nail it. I made the hole bigger, and my Filter Minder started behaving. Basically... the AIS can handle anything a stock truck can do, but a chipped truck is a modified stock - so you need to modify the AIS.
The S&B is decidedly louder - but nothing close to a 6637 in any configuration. The S&B housing is wide open on the fender side, and the snout has a slightly larger opening than the AIS snout. What this says is - it's the housing, it's the housing, it's the housing that limits the flow as much as the filter.
Old Nov 26, 2016 | 10:29 AM
  #33
CampSpringsJohn's Avatar
CampSpringsJohn
Yes, with a 38R, that was my experience. But, I don't think the AIS made enough difference in noise reduction to justify buying one if you already have an S&B.
G707minniemo
May 10, 2008 12:11 PM
mudmaker
19
Nov 23, 2007 12:58 PM
DPMPSD
Feb 16, 2006 09:06 AM
smokin redneck
33
Nov 22, 2004 08:17 AM
RedStroker6
13
Oct 5, 2004 11:35 AM
