Stop LIght Switch Questions
Old Nov 22, 2016 | 09:47 PM
dancraig's Avatar
dancraig
Hello:
I'm back with another question I'm embarrassed to ask, but better to ask than to wish you had...later.
My brake lights started to stay on. I decided to buy a new stop light switch and make a quick repair. Put the new one in and got the same effect...lights stay on.
I'm thinking maybe I got the wires crossed. Now I plan to switch them and see if that fixes the problem.
Question: Before I try this is there a problem I should be aware of. Like could I burn something out, fuse or bulb or whatever, by crossing the wires?
Thank you very much for any reply.
Old Nov 23, 2016 | 03:15 AM
dancraig's Avatar
dancraig
I went back and found some "red" on one of the old truck wires and some red lines on one of the new switch wires. So I think I have it connected correctly.
Now the brake lights don't work at all. They were stuck "on" with the old switch. All other lights, including back up lights, are fine.
Any thoughts or advice greatly appreciated.
Old Nov 23, 2016 | 04:27 AM
dancraig's Avatar
dancraig
I've gone back and now realize that although the dealer website calls the part I replaced a "stop light switch", it seems that I have only replaced the connector to the switch.
The switch looks like this Duralast Stoplight Switch F4829- ReadReviews onDuralast #F4829
Looks like it is held in place with a pin, of some sort. It has a small spring inside and plugs into the black plastic part I have already replaced.
I can't find any replacement instructions. Can anyone give me some advice or point me in the right direction?
Thank-you.
Old Nov 23, 2016 | 05:54 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Yes, it's held in place with a little clevis pin.
The brake pedal is connected to the booster pushrod by a pivot pin, the switch goes in this interface, the pivot pin goes through and the clevis pin keeps it all together.
I did this in the Advance parking lot.
A pair of needle nose pliers helps if you have fat fingers like me.
Old Nov 23, 2016 | 05:57 AM
Franklin2's Avatar
Franklin2
Pay attention how it comes apart. It's not set up like you would think and can be confusing to put together.
Old Nov 23, 2016 | 12:54 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
E3TZ-13480-B .. Stop Lamp Switch (Motorcraft SW-1576-A) / Obsolete ~ Available NOS & from auto parts stores.
1980/82 F100 with manual or power brakes / 1983 F100 / 1980/85 F150/350 & Bronco.
Old Nov 23, 2016 | 01:09 PM
dancraig's Avatar
dancraig
Got it replaced.
Thank-you all for the help.
Old Nov 23, 2016 | 06:10 PM
FuzzFace2's Avatar
FuzzFace2
Originally Posted by dancraig
Got it replaced.
Good to hear you got it changed out.
Did it fix the issue of the lights staying on the not on at all?
Dave ----
Old Nov 23, 2016 | 09:03 PM
dancraig's Avatar
dancraig
It fixed the "on all the time" part. I had blown a fuse installing the black plastic connection part of the switch. A new fuse fixed the "now off all the time" part.
Thank-you.
Old Nov 24, 2016 | 05:16 AM
FuzzFace2's Avatar
FuzzFace2
Off all the time LOL
Only reason I ask is if some does a search for "brake light" and finds this post it will have the fix. I have seen it posted some one find the same thing wrong and no "finish" to the post.
Good to hear all is working as it should.
Dave ----
smangold
Jun 14, 2021 06:41 AM
dnkensinger
Jun 7, 2016 10:30 PM
cesspool
May 11, 2010 10:11 AM
missviv2
Nov 1, 2006 12:07 PM
bloodynuckles
Electrical Systems/Wiring
Aug 20, 2003 12:56 AM
